cleaning hks filters
Old Nov 8, 2002 | 04:08 PM
anyone just wash out their hks foam air filters instead of replacing them? what would be the harm of cleaning them with water since they are a foam element?
Old Nov 8, 2002 | 04:14 PM
Mahjik's Avatar
Mr. Links
Re: cleaning hks filters
They get brittle from the heat and washing them would tear them up more. If you do that, they might begin to break apart while you are driving and your turbos will be chewing up your foam filter fragments.
They are cheap, just replace them. Get some K&N oil and work through them before installation.
Old Nov 8, 2002 | 07:35 PM
Cetchup's Avatar
The Cursed FD
Just get new filters. They are relatively cheap and can be found at your local race shop. Don't use any oil on them, they are foam so they absorb liquids. They are not meant to be cleaned at all. They are disposable.
Old Nov 8, 2002 | 10:27 PM
duboisr's Avatar
REPLACE them with K&N filters
Old Nov 8, 2002 | 11:28 PM
RotaryKnight's Avatar
Cetchup is correct. HKS filters are not meant to be reused. They have oil in them so washing them would strip the oil....the oil is NOT the same as a KnN filter.
Chris
Old Nov 9, 2002 | 03:34 PM
teamstealth's Avatar
Ozone Depleter
If you don't have any filter oil you can use WD-40 instead.
Peace,
Zach
Old Nov 9, 2002 | 10:10 PM
WD-40 is not the same.
Replacement filters are 10-20 depending where you get them. Just buy new ones.
Chris
Old Nov 10, 2002 | 03:22 AM
Quivver's Avatar
Where can you get them I need new ones, actually today I went to pep boys to see if they could order them, alsoI have the petit intake.
Old Nov 11, 2002 | 07:26 AM
Foz'sRX-7's Avatar
How many miles on your intake & filters?
Snoopy FD
Dec 8, 2015 01:45 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
