Front Fascia Question
Old Nov 5, 2002 | 08:41 PM
johnchabin's Avatar
Anyone removed these two plastic pieces on either side of the opening for the radiator/IC/etc? I think they are behind the driving lights on a touring model, but I have a base model and would like the added airflow.
Are they easy to take off? I can't see behind them to see how they're attached and I don't want to snap the 10 year old plastic...
Old Nov 5, 2002 | 10:21 PM
xstacy7's Avatar
I love when things work
i think they actually hold/support the front fascia, i've seen them taken out for FMIC's but i don't know if they're removable for stock?
Old Nov 5, 2002 | 10:27 PM
Import Convert's Avatar
My R1 does not have those.
Old Nov 5, 2002 | 10:34 PM
johnchabin's Avatar
Maybe I'll get a mirror and look from the back. Seems like they're just blocking airflow right now.
Old Nov 5, 2002 | 10:49 PM
johnchabin's Avatar
I went and tugged on it a bit. The bottom seems loose, like it would just pop out. The top is attached somehow. Maybe they stopped the driving lights from blowing off.
Old Nov 5, 2002 | 11:08 PM
skunks's Avatar
I'm a CF and poop smith
the airflow would not be going into the radiator though unless you made yourself a pair of shields. those are to duct air in to the radiator.
Old Nov 6, 2002 | 08:04 AM
ptrhahn's Avatar
You should sheild around you rad Anyway. I removed the from my 93 tourer.
Old Nov 6, 2002 | 08:17 AM
johnchabin's Avatar
I don't see how the airflow could go anywhere else. If I took off this piece, it just would make the inlet hole larger... I just don't want to break it when removing.
Old Nov 6, 2002 | 09:43 AM
neoamd's Avatar
LS Powered
use and exacto knife and chop away
Old Nov 6, 2002 | 01:47 PM
hapa's Avatar
I removed these 3 years ago, just to open up the fascia to the radiator some more. I was in there ducting off the radiator with duct tape, and had the bellypan removed. I believe there were 2 or 4 screws per plastic piece. A total pain in the *** to remove but I think it opens up the fascia for more air.
eric
Old Nov 6, 2002 | 03:11 PM
johnchabin's Avatar
eric
Great. I'll pull the bellypan and have a look.
Seems like getting rid of these will allow more air in. Again, they appear to have no function for a base model without lights. I'm not even sure what they are for if I did have driving lights. Perhaps they're for the mounting bracket?
Thanks for the help.
John
Old Nov 6, 2002 | 06:26 PM
maxpesce's Avatar
Ex fd *****
On a Touring w/ Fog lts They are much smaller I think they are designed to make the airflow equal w/ & w/o the fog lts.
Old Nov 6, 2002 | 06:48 PM
JBC's Avatar
JBC
They pop right out. You do have to pull pretty hard. I don't think mine were attached with a screw or anything. You have to pull from the bottom and get it loose than get it unhooked on the top
Old Nov 6, 2002 | 08:42 PM
johnchabin's Avatar
I got the bottom out (lift & push back), the top out (pull forward, taking the screw out helps), and the side is still in (feels like it pulls forward too, but I don't want to pull harder & break it).
I put it back to original. I'll look again when it's light out. Oh, well.
Old Nov 6, 2002 | 09:11 PM
P'cola FD's Avatar
Hamado things my way!
I didn't even know those existed. Take 'em out.
Old Nov 6, 2002 | 10:11 PM
johnchabin's Avatar
Maybe they put them in to block airflow to the radiator, since the FD tends to run a bit too cool.
Yikes!
matty
Jan 18, 2020 10:39 AM
OrangeMax
Sep 4, 2015 10:42 AM
