If My Cat Is High Flow Would I Still Need My Airpump
Old Nov 5, 2002 | 07:57 PM
mazda/feed's Avatar
I think that my damn cat is clogged again and this will be the second one, so i want to go with a high flow but i really dont want to pay $900 for an air pump, so to thsose that know. would a high flow cat convertor need the air pump if its high flowing
Old Nov 5, 2002 | 08:11 PM
Mahjik's Avatar
Mr. Links
Yes, you still need the air pump.
There is one of them (I think N-Tech) that says you don't, however I think they are full of crap.
Old Nov 5, 2002 | 08:13 PM
c00lduke's Avatar
You only need it if you plan on passing emissions
Old Nov 5, 2002 | 08:14 PM
Mahjik's Avatar
Mr. Links
Any if you want to extend the life of the cat...
Old Nov 5, 2002 | 08:16 PM
rx7raca's Avatar
wHiTe kNiGhT
so as long as u have the pump u will pass emissions?
Old Nov 5, 2002 | 08:19 PM
Mahjik's Avatar
Mr. Links
No, that's not necessarily true. There are other things that can cause you to fail emissions other than the air pump. However, you won't pass without it.
Old Nov 5, 2002 | 08:29 PM
sanfordman's Avatar
An air pump changes nothing in the emissions test as far as I have heard, but if they look under the hood and see you dont have an airpump they can refuse to pass you, some places are **** about it, others dont even really bother to look (although they are supposed to). I have a high flow cat and I just removed my airpump totally. You do not need to upgrade your airpump if you get a high flow cat (unless you really want to spend that money to please the government...).
Old Nov 5, 2002 | 09:16 PM
dclin's Avatar
Perpetual Project
The role of an airpump is to provide O2 in the cat to aid in chemical process of cleaning the emmisons. With a quality hiflow cat, an airpump is not neccesary, though rotarys are dirty and will likely be neccesary to pass emmisions. Not having an airpump with a hiflow cat does not neccesarily mean it will shorten the cats life significantly.
However, it is possible the stock (highly restrictive) cat or a low quality cat may clog deteriorate quickly w/o the airpump. A cat needs to get hot for it to work correctly, but it's reasonable that with a restrictive stock cat, TOO much heat can build up and cause problems.
There is no real conclusive evidence one way or another.
Old Nov 5, 2002 | 09:30 PM
neo_omega's Avatar
***Moderator***
seems you know nothing. You need to learn more.
Old Nov 5, 2002 | 09:40 PM
gohorns's Avatar
If you dont have an airpump then just get a midpipe and if that is too much flow then have a muffler shop weld in a muffler
Old Nov 5, 2002 | 09:43 PM
azndisgrace's Avatar
LOLOLOLOLOLOL..
air pump changes nothing??
HAHAHAHAHAHAHAHAHAHAHAHA
i agree with neo... go read something
Old Nov 5, 2002 | 10:02 PM
kwikrx7's Avatar
An air pump will help extend the life of a HF cat..but not sure how long. I've been running without my airpump for 1.5 years now without problems - I got a quote "HF cat" off the net..ended up being gutted so it was basically a midpipe. I had a HF cat welded on but didn't have a hookup for the airpump..I'm sure in a few years it might cause problems..but if it did, I'll just get another one welded on for $150 from Meineke
Old Nov 5, 2002 | 10:16 PM
Batmobile's Avatar
YEs...without an airpump...the main cat will be clogged...mine broke and six months later...nasty smell through the cockpit.
Old Nov 5, 2002 | 10:53 PM
johnchabin's Avatar
Buy a used airpump. They're on here/ebay/thepartstrader quite often. You should get one from a midpipe convert for less than $100.
Old Nov 5, 2002 | 11:00 PM
neo_omega's Avatar
***Moderator***
you can also try vette airpump too.
Old Nov 6, 2002 | 08:01 PM
mazda/feed's Avatar
well i dont want to keep buying cats and another air pump, but this is for those that went with the mid pipe how loud is it, i mean i have at gt catback and thats loud as all hell, i love it and also would i need to get an external wastegate
Old Nov 6, 2002 | 08:51 PM
rx7raca's Avatar
wHiTe kNiGhT
quick question, if you get a dp will u pass emissions with no problem, or might be on the edge of passing?
Old Nov 11, 2002 | 05:38 PM
allrotor93's Avatar
so share something with us....you havent proved your point yet either. i am not sure myself so please enlighten me. thanks.
Old Nov 11, 2002 | 05:56 PM
sanfordman's Avatar
http://www.scuderiaciriani.com/rx7/air_pump.html For all intensive purposes it does nothing...
Old Nov 11, 2002 | 07:33 PM
Tom93R1's Avatar
gross polluter
My car was dumping about 5X the legal limit at idle for, I dont remember if it was HC or NOx, until I discovered the air pump was not connected. Had a bung welded to the cat and fed the air pump into it, after that I passed with about 1/2 the limit of whichever the offending molecule.
Old Nov 11, 2002 | 07:42 PM
jpandes's Avatar
I bought the N-tech hi flow cat. I ran the car for a month w/o the airpump and my car wouldn't idle at all and smelled aweful.
Once I connected the airpump, the car idled fine and stopped smelling foul.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
