boost with full Racingbeat on 89t2
Old Aug 1, 2001 | 12:54 PM
Scott 89t2's Avatar
SOLD THE RX-7!
here's some info on doing some "tests". 2 days ago I installed a full 3" racingbeat, fcd, and greddy P/H EGT into my 89. with a K&N cone, crane hi-6 ign, and rewired stock fuel pump already. also a manual boost controler turned all the way to "-" (so I was running 5psi before exhaust as stock controler was bypassed)
with exhaust and k&N cone I got 5psi in first, 8 in 2nd, and barely hit 10 in 3rd at about 5500 but then it droped back to 8 by 6000. in forth on the highway I slowly creeped to 11psi then let off as I didn't want to go over 10. even here I only hit about 800C (1500F) so the fuel was ok.
with exhuast and stock air box.
5psi in first, about 7 in 2nd, 8 or 9 in 3rd. and barly hit 10 before droping while WOT up a big hill in 4th at 5000 or so. once again right at 800C so doing just fine fuel wise.
so on a 89+ turbo with a stock airbox the racingbeat exhaust seems to be ok fuel wise and it stays under 10psi with the stock controler disabled.
now to play with the controler to get 8-9 psi in every gear and lower in the rpm range instead of slowly creeping from 5-9 over the rpm range.
oh and the exhuast sounds so SWEET!!
http://www.1300cc.com/IMAGE011.jpg
http://www.1300cc.com/IMAGE012.jpg
Old Aug 1, 2001 | 02:10 PM
dcamcoTII's Avatar
So is it a completley different beast??
Old Aug 1, 2001 | 02:21 PM
Scott 89t2's Avatar
SOLD THE RX-7!
o yeah!!
you will probably have worse creeping problems with yours though.
thats low miles!
Old Aug 1, 2001 | 02:39 PM
dcamcoTII's Avatar
Thats what I am told, but thats not a problem because the wastegate will be getting ported with the exhaust install---also, did you have any difficulty installing the RB?
Old Aug 1, 2001 | 03:45 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I didn't do it. but the guy who did had some problems. if the precat has never been taken off it's a pain in the ***. there is a heat shied with like 8 bolts you have to take off and they are all hard to get to. then under that there is a metal "clip" thing that wraps around all 3 precat nuts so they won't come loose over time.
Old Aug 2, 2001 | 10:56 AM
dcamcoTII's Avatar
Damn, sounds like this one could be a PITA--wish me luck...
Old Aug 2, 2001 | 02:15 PM
FC3S's Avatar
Hey Scott. We have almost the same set up. I have the RB full turbo exhaust, MSD 6A, HKS FCON, and HKS filter, no boost controller. Before I was running only the exhaust, MSD, FCON with stock filter and I got 8 psi in every gear no creep at all and my EGT reading is about 1300 F. With the exhaust MSD, FCON and HKS filter it reached 9 psi in first, 10 in second, but creep all the way too 14-15 from 3rd to 5th.... I was afraid to step on gas. I am local to you so maybe we can exchange some openions.
Old Aug 2, 2001 | 06:44 PM
Scott 89t2's Avatar
SOLD THE RX-7!
what year is yours?
is it black with a "redzone" or something like that sticker above turbo II?
Old Aug 2, 2001 | 08:03 PM
fcturbo2's Avatar
Hey guys!..i will have the same setup on my 87TII. I also purchased an FCON and just wondering if the FCON is a great buy!..I have
RB full turbo back system
HKS intake
HKS FCON
FCD
FMIC
will get...
Compressor upgrade
gauges
Old Aug 3, 2001 | 02:22 AM
FC3S's Avatar
Yes my car is black 88 TII with the redzone sticker on the side.
Hey fcturbo2 we have almost the same set up. I am wondering how many psi of boost are you running and what FMIC is yours.
C. Ludwig
Jan 30, 2019 06:31 AM
Skeese
65
Mar 28, 2017 03:30 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
CaptainKRM
15
Aug 29, 2015 01:33 PM
Turblown
Aug 14, 2015 04:48 PM
