Need help with my 12A!!!
Old Oct 28, 2002 | 11:20 AM
1stGenRX's Avatar
Last night I started my RX-7 and I hadn't driven it in two days so I opened the hood to check the engine, and fluid and what not. Well near the bottom of the engine there was a red glow. It looked like the engine was burning red hot and then it actually started sparking. Anyone know what is wrong with my engine?
Or is this normal and I have just never noticed it before?
Thanks for the help!
Old Oct 28, 2002 | 12:33 PM
Suparslinc's Avatar
It's Back!
was it your exhaust manifold glowing red and your plug wires sparking? Those two would seem to go hand in hand
Old Oct 28, 2002 | 12:44 PM
damon's Avatar
sounds like your running lean or a clogged cat?
peace
Old Oct 28, 2002 | 02:57 PM
1stGenRX's Avatar
I am not sure if it was my exhaust manifold glowing red. Is that normal? But the sparks were coming from the part that was glowing red, not from the plugs. Which makes me think that this is not normal.
Old Feb 26, 2003 | 03:37 PM
HELP! I got the same problem my manifold is burning RED HOT and the exhau
Old Feb 26, 2003 | 03:41 PM
specRX7_22's Avatar
which side of the engine bay? ive heard of manifolds glowing red but ive never heard of sparking.
Old Feb 26, 2003 | 03:49 PM
actually no sparking its just red hot on the passenger side.84gs
Old Feb 26, 2003 | 04:17 PM
specRX7_22's Avatar
then its gotta be the manifold. as damon said, your probably either running lean or you got a clogged cat.
Old Feb 26, 2003 | 04:27 PM
Im sorry what does "running lean" mean? I removed all the cats.
Old Feb 26, 2003 | 05:42 PM
jonfc3s's Avatar
not enough fuel to the engine,... causes it to run hotter
Old Feb 28, 2003 | 04:22 PM
so what can I do?
Old Feb 28, 2003 | 05:06 PM
fine tune your carb.
Old Mar 1, 2003 | 06:32 AM
RotorMotorDriver's Avatar
Seven Is Coming
Mine did this too when my trailing ignition wasnt working, and also again when I had the car running on a basically dead battery.
~T.J.
Andrew7dg
Aug 6, 2017 01:41 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
