Fire!!!!!!!!!!!
Old Oct 27, 2002 | 09:50 PM
Fire!!!!!!!!!!!
I have and 83 and I pulled up to my friends house and had to jump out because there was smoke billowing out of the cab. I have come to the conclusion that the choke cable was touched by a shorted out wire on the wiring harness. This started the plastic cover on the choke cable on fire. There is no more fire now so i think the short burned in half. Now when i hit the gas there is a delay or at slow speeds even boggs down. What in the world happened?
Old Oct 27, 2002 | 10:24 PM
Suparslinc's Avatar
It's Back!
I had almost the exact thing happen to me.
I think something shorted out on the cruise cable, it got hot and in contact with a fuel line which burnt and spewed gas all over my engine. The whole cab filled up and my windows stopped working so I knew something was up; the whole damn car almost burnt down so consider yourself lucky , could have been alot worse.
I had to rewire my entire harness one wire at a time. It took about 8 hours. You should check every wire and every vacuum hose and cable.
Old Oct 28, 2002 | 03:02 PM
Thanks alot is there anywhere i can buy used harness?
Old Oct 28, 2002 | 05:11 PM
Suparslinc's Avatar
It's Back!
ha lots of luck I believe they are $800 from the factory. Since they are worth their weight in gold you will not find people giving them up easily. Just because you had a fire doesn't mean your harness is shot though, just a suggestion.
Old Oct 28, 2002 | 09:12 PM
jr69187's Avatar
just sold engine harness the other day. I have the full dash harness though with fuse blocka dn everything.
jr
Old Oct 28, 2002 | 10:33 PM
RotorMotorDriver's Avatar
Seven Is Coming
I have all the harnesses from an 84 (as far as I know), the car ran before it started getting parted out. As is. Let me know what you think a fair price is .
~T.J.
ls1swap
Jun 3, 2024 03:25 PM
Aramir
Oct 18, 2015 02:39 AM
LongDuck
Oct 7, 2015 08:12 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
