What the hell is a rats nest?
Old Oct 26, 2002 | 04:10 PM
Rex79's Avatar
Old Oct 26, 2002 | 04:28 PM
joelwahid's Avatar
give the old search button a shot. that should answer your question.
Old Oct 26, 2002 | 04:29 PM
Rex79's Avatar
I did and I couldn't find anything... it just kept on looking for ''rats nest'' but I didn't find any info on it... I just see a lot of people saying they removed their rat nest....
Old Oct 26, 2002 | 04:34 PM
joelwahid's Avatar
thats my rats nest. does that help any?
Old Oct 26, 2002 | 04:37 PM
Rex79's Avatar
well not really.... I'll go take a picture of the engine and put them on the computer right after,,, so you can tell me what it is lol
Old Oct 26, 2002 | 04:44 PM
joelwahid's Avatar
its the jumble of hoses and stuff behind the alternator. if your car is a later year than 79 or 80 it should be the blue and green and yellow plastic things (probly like 5 of em) with all the hoses and stuff looking kinda like a rats nest.
Old Oct 26, 2002 | 04:45 PM
jeremy's Avatar
male stripper
it is the term given to the ample amount of vacuum lines running across the engine, thus looking like a "rats nest". the 3rd gens are even worse with the factory sequential twin turbo system.
Old Oct 26, 2002 | 04:54 PM
Rex79's Avatar
ohhhh ok it's all the hoses hehe I saw one of my friends change all his hoses on a 3rd gen for silicone hoses... do you think it would be worth all the hassle for a '79 RX-7? Cuz I touched mine and they're really really hard so I don't know if it's worth it...
Old Oct 26, 2002 | 04:57 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
You call that a rats nest, thats so simple. Look at the cosmo one, and thats only like 3/4 of it. You ought to see all the vacuum lines to the turbos
Old Oct 26, 2002 | 05:21 PM
Rex79's Avatar
Then I guess this is my ''rats nest'' :P
Old Nov 14, 2002 | 02:58 PM
Rex79's Avatar
and what do those yellow,blue and green plastic things do? If I remove them, what will change? any performance? what do they exactly do? because I know that one is just sticking out without being attached to anything...need some more info on what they do please
nick
Old Nov 14, 2002 | 03:37 PM
fatboy7's Avatar
Got Boost?
They are solonoids that control different aspects of the engine (vacuum advance, secondary air system, etc.) I think if you have removed, or are going to remove the emissions equipment, that it can be removed. but if you need it to pass, it needs all of those.
Old Nov 14, 2002 | 03:47 PM
error402's Avatar
#!/sup_mod/üb3rg33k
nick
Usually there is a sticker on the underside of the hood that tells you what each solonoid does.
-Error402
Old Nov 14, 2002 | 03:49 PM
Mark S's Avatar
I would only change all the hoses if your pulling them to do something else. They're probably hard, but I bet they're fused in place, so are probably air-tight. If you have to remove them, they may not seal as well which would warrent a change.
If you do change them, don't waste your $ on silicon. I know on a 2nd gen, it's like $90 worth of hose...
Rubber hose works fine for NA 7s.
Old Nov 14, 2002 | 04:17 PM
Dude get rid of the ******* rats nest it slows your car down
Old Nov 14, 2002 | 05:20 PM
Project84's Avatar
Open up! Search Warrant!
Thats cause there's an infinite amount of threads for it to spool together cause this question gets asked more times than any 25 questions combined.
Old Nov 14, 2002 | 05:23 PM
Project84's Avatar
Old Nov 14, 2002 | 05:55 PM
error402's Avatar
#!/sup_mod/üb3rg33k
These should help, I just did a quick search in the 1st gen section with "rats net removal".
https://www.rx7club.com/forum/showth...s+nest+removal
Hope that helps you.
-Error402
Old Nov 14, 2002 | 09:43 PM
jtn
Thanks but I am still looking for a step by step , any one?
Old Jun 20, 2003 | 02:57 AM
jimmyrose99's Avatar
theres a 16mb pdf download at ftp://ftp2.totalimmage.com/ti/Tutorial_1.pdf
but i havent read it yet
Old Jun 20, 2003 | 03:49 AM
O 16581 72452 5's Avatar
The infamous number guy!
Actually it doesn't, people just remove it to simplify the engine bay and make it look less cluttered.
ls1swap
Jun 3, 2024 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
Jetlag
Sep 29, 2015 06:52 AM
