help me diagnose these leaks
Old Jul 30, 2001 | 07:57 PM
suganuma's Avatar
no
ok i have 2 problems....
1. i was running 11 lbs on my profec when suddenly at about 5k-5500 boost drops to 9. since then my boost has read 2 psi low everywhere no matter if the profec is turned off or on. turned off that means it would run 5.5 instead of 7.5 like usual. any guesses or suggestions of where to look first?
ive never had a boost leak before
2. for a while ive been hearing a whooshing like a large boost leak at partial trottle but it does NOT happen when im under boost. some have told me this is due to the fact that im venting my bov to atmosphere
do yall agree or have other suggestions of where to look?
thanks in advance for the help
Old Jul 30, 2001 | 08:00 PM
suganuma's Avatar
no
i knew i was forgetting something....
also when i first turn the car on and sometimes before its warmed up and ive been sitting at idle for a while the check coolant light will come on. this has happened ever since the installation of my fluidyne radiator. in the shop manual it says this may be due to a bad alternator.
anyone had this problem??
just looking for other possible solutions before i go get a different alternator and stuff
how can i check my alternator independently??
if you have a page number in the shop manual for directions on this i can just follow that
thanks
Old Jul 31, 2001 | 12:41 AM
TainoIndian's Avatar
hmm...
whats going on Nic!!
I am having boost problems my boost gauge showed 8-6-8???
could this be due to the high elevation im in????
Also...have you met TOM93R1? he lives in the springs also..cool guy, i met him on this forum and he stopped by at my place today and showed me his red R-1!!.... NICE!!
good luck....please help this guy out...and me also!!!!
THANKS
Old Jul 31, 2001 | 03:26 AM
suganuma's Avatar
no
well i go drive tonight for the first time today.....and suddenly im getting 7.5 lbs again.....weird
the only thing i did was put a different intake pipe to the rear turbo and put a zip tie and sealant around the boost gauge's vacuum line cause i noticed it was a little loose
oh and i decided to try out venting my crv to atmosphere
....strange
im still getting the pshhh sound at partial throttle though
but damn......does no one give out help anymore???
no one answers anything in the tech support OR here apparently
i know someone's had to have something like this going on.....
and ya your 8-6-8 might be due to altitude....apparently people have all kinds of crazy crap go on up at altitude. try testing out your map sensor though. its right up against the firewall on the drivers side.....little black box with a vacuum line going to it and some wires. is the car stock??
Old Jul 31, 2001 | 11:07 AM
Arrow
Hey Nic,
I would have replied but I have no idea what could be causing your problems man . Too bad you're going back to CO soon...I was planning on helping you next time I'm in the Dallas area.
take it easy,
Old Sep 5, 2002 | 05:23 AM
ryoshimura's Avatar
i also have that whooshing sound at partial throttle which doesnt appear during full boost. i have done the non seq. mod but my boost seems to still drop off towards redline. when i hit high rpms it doesnt pull as hard and it sounds like its not boosting anymore. if you can tell me anything about why this is happening i would appreciate it.
Old Sep 5, 2002 | 08:21 AM
johnchabin's Avatar
Colorado Guys...
We should all get together and discuss our boosting woes. That makes three of us. I do know what is wrong with mine, though. But I have to take off the Extension Manifold.
I have a good diagnostic procedure for troubleshooting the sequential system. Well, it helped me anyway...
I've decided low boost is not an altitude issue. Slow build, maybe.
suganama: how low is the coolant level in the filler neck before you start the car?
Old Sep 5, 2002 | 08:39 AM
redrotaryrock8's Avatar
alternator test is pretty simple: i suggest you get a hold of the shop manual and follow the steps.
you use an amp meter- takes two seconds. dont know how much resistance it should have, therefore, suggest looking at the shop manual.
Old Sep 5, 2002 | 02:56 PM
suganuma's Avatar
no
DAMN THIS THREAD IS OLD!!!!!!!!!
it was JULY of 2001 when i wrote that!!!!!
i did a hose job and that fixed the problem for a while - found 2 bad check valves, but shortly after that point, i went non-sequential......that was SO long ago it seems........lol
Old Sep 5, 2002 | 03:34 PM
johnchabin's Avatar
That's funny... I never notice the dates.
I thought I remembered that you said you went non-seq.
Old Sep 5, 2002 | 03:35 PM
johnchabin's Avatar
What was the solution to the low coolant buzzer?
Old Sep 5, 2002 | 03:37 PM
suganuma's Avatar
no
um....dont remember
i think i just drained the entire coolant system and refilled it and it stopped...
i am actually not non-sequential anymore either - they are sitting in my room for sale. T61 is in the mail...
Old Sep 5, 2002 | 03:41 PM
suganuma's Avatar
no
john, GET AIM!
most of us in CO have it and it's a great way to keep in touch. i have diagnosed several boost problems with my car when i had it. maybe if we meet up sometime I can give some sort of help or think of something that y'all havent yet.
Old Sep 5, 2002 | 09:22 PM
johnchabin's Avatar
I have an AIM account... it's also johnchabin
I know, not very original.
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
