720 woes
Old Oct 19, 2002 | 05:46 AM
slidingsky's Avatar
720 woes
I recieved my denso 720s the other day, thanks brock. They are going in my 90 TII. I went to buy resistors and guess what? Radioshack has DISCONTINUED all the 5watt and up resistors. Im kinda screwed, Im gonna try a local computer shop. They maybe able to get them.
If you have a S5 make sure you get the resistors before you get the injectors. I think you need 1-1.1Kohms at about 10-20 watts<reted advised>. Oh also the injector wiring plugs are diffrent. What did you guys do for this? I took S4 plugs from an extra harness. I can just splice these instead of the S5 ones right?
Sky
Old Oct 19, 2002 | 07:59 AM
KNONFS's Avatar
B O R I C U A
Check on a GOOD CAR AUDIO shop, they use\need resistor to build custom passive cross overs.
Old Oct 19, 2002 | 12:31 PM
DaleClark's Avatar
RX-7 Bad Ass
Radio Shack's webpage still lists the resistors - you can buy them online. They show availability for them in the stores as well as online. I think you may have been fed some BS by the store clerk.
They're 10ohm, 10watt resistors.
Dale
Old Oct 19, 2002 | 03:37 PM
BlackFC's Avatar
The injector connectors can also be gotten from the HELP isle at Pepboys ect. Its a standard bosche FI plug. Like $6 - $10 each (kinda pricey) but they work.
Old Oct 19, 2002 | 10:07 PM
slidingsky's Avatar
10 ohm, are you sure. My 90 ones are 14000ohms, the denso 720s are 3000. Isnt that about 1kohm diffrence. Oh also I got them from a computer shop. I guess 1amp flows through the injector so 10 watts isnt enough. I have 2 10w 500ohm in serise. THe guy at the shop recomended it instead of 1 1k 10w.
thanks for the input.,.
Old Oct 19, 2002 | 10:43 PM
cbrock's Avatar
Glad you got the injectors. Just a thought, but can you get a resistor pack off a S4 and wire them through that?? The guys are right though, radio shack should be able to get you just about anything. Hell I've seen night vision goggles in their catalog. Good luck
Old Oct 19, 2002 | 11:05 PM
Scott 89t2's Avatar
SOLD THE RX-7!
ummm... 14000-3000 = 11000 =11k
Old Oct 20, 2002 | 01:36 AM
Makenzie71's Avatar
...94% correct.
what are the resistors for?
will the diff injectors not work right without it?
Old Oct 20, 2002 | 01:47 AM
Rpeck's Avatar
What R U thinking self?
Read these 2 posts .. covers alot of info on the resistor setup;
https://www.rx7club.com/forum/showth...hreadid=121793
https://www.rx7club.com/forum/showth...threadid=98990
Old Oct 20, 2002 | 07:59 PM
slidingsky's Avatar
YEs sorry I did get those worng. Thanks for all the help guys.
vaughnc
21
Jul 11, 2002 04:31 PM
importboi22
Jul 7, 2002 01:06 PM
thePoint
Jun 6, 2002 12:42 PM
EProdRx7
Jan 2, 2002 08:39 AM
