Drivers door wont open!!!
Old Oct 17, 2002 | 04:36 PM
silverrotor's Avatar
I tried opening It with a key (duh) and from the Inside handle. It won't budge. I just tried to Jimmy It open but nothing happens.
The push lock, from the Inside handle, goes up and down unlocking/locking the doors aswell as activating the Factory Alarm. I'm begining to think that It Is the handle. If so, how the heck am I going to open the door to get at the skin to remove the handle?
Old Oct 17, 2002 | 06:56 PM
rx7sam's Avatar
Angry yeah
Yeah same with my door, It wont open anymore, its the handle....damn its soo irritating. But I tried fixing it, and I couldnt get in further. HELP US BOTH!!
Old Oct 17, 2002 | 08:30 PM
ra ra rotory's Avatar
my driver door is skrewed up and has been since i bought my car, it looks like someone jamed a skrewdriver in the lock, iv been inlocking it from the pas side for months, do i just need a new lock assembly, will the security system still work im i just take it to a smith? help!
Old Oct 17, 2002 | 09:11 PM
I bang up everything, trying to get from the Passengers side to the Drivers seat with my big *** Doc Martins.
I can't repair It, considering I can't even open the door!Anyone?
Old Oct 17, 2002 | 09:21 PM
Scott 89t2's Avatar
SOLD THE RX-7!
can you not open it from the inside either??
Not to be rude but you already answered your question.
Old Oct 17, 2002 | 10:26 PM
ebay7's Avatar
If you lock it from the inside then the factory alarm will be armed. But if you locked it from the outside(with a key), then it won't armed. I'm pretty sure of that but don't blame if your stuff get stolen and it didn't trip.
btw, the cost for these new door handles are over $85ea, and over $140 for the fancier ones(ie light illumination and alarm), couldn't I just swipe one from a junk yark?
Old Oct 17, 2002 | 10:30 PM
No. From outside and Inside, I can't open It. The lock moves freely like It did before.
Old Oct 17, 2002 | 10:32 PM
btw, the cost for these new door handles are over $85ea, and over $140 for the fancier ones(ie light illumination and alarm), couldn't I just swipe one from a junk yark? [/B][/QUOTE]
Yea they are Interchangable If you don't mind not having the Key light feature when you lift the handle.
Old Oct 17, 2002 | 11:37 PM
silverrotor- yeah you are right i guess i did answer it, but the alarm system, i want to be able to fix my lock, yet still use the factory alarm, like be able to set it from out side? how would i go about doing this, just get one out of a yard and get a new one (would a smith be able to make so i can use my old key?)? or is it something a lock smith would be able to fix?
Old Oct 18, 2002 | 12:02 AM
I doubt you'll get a match for your lock from a scrap yard. Best bet would be to get a new lock from the Dealer.
As for your Factory Alarm right now, I would try to shutting and locking the Drivers door. Swing around to the Passengers door. Open It. From the Inside handle, lock the door then close the door but simutaneously hold the handle up. You should have the Factory Alarm engaged. If that doesn't work than you need to start checking connections.
Old Oct 18, 2002 | 12:12 AM
why couldnt he just swap lock cylanders? thats what i did with mine
Old Oct 18, 2002 | 01:14 AM
If you read the post correctly than you would have understood a screwdriver was driven Into his lock. Therefore his lock needs to be replaced. Not the lock cylinders.
Old Oct 18, 2002 | 06:25 PM
Can you roll your windows down? If you can just jump in "Dukes of Hazard" style J/K- Craig
Old Oct 18, 2002 | 06:29 PM
HAHA the dukes of hazard kick ***, but yeah silverrotor- I dont think the alarm actually runs of the lock, im thinking it runs of the inside locking mechinism, so therefore, replacing the lock itself wouldent effect the alarm as long as the inside part still goes down when you lock it. If that makes any sense at all haha. anyway, thanks alot for all the help.
Old Oct 18, 2002 | 08:49 PM
I would attempt to "Dukes of Hazard" It but I don't wanna mark up my new Momo Millenium Steering Wheel. Dude Is coming buy tommorow. I suspect the link Is broken/seperated from handle.
seveninphilly's Avatar
on the road to insanity
1.After taking a look at my car it seems you could remove the drivers side seat (as to have enough room to work) pull it out the passenger side
2.take everything off the door panel (arm rest, release handle cup, screw in bottom left corner)
3. Pull the door panel back and get to the lock mechanism to open the door and fix properly(yes where it meets the dash it will still be attached but you can bend it out enough to get to the lock)
Old Oct 18, 2002 | 08:54 PM
Your very limited this way. Plus I'm not sure If that Is possible. There Is a matter of another screw that holds the skin up. Then again, you are limited. I'll keep you updated.
Old Oct 18, 2002 | 09:07 PM
The only other screw I know of is the one in front of the vent upper right hand corner. The rest are plastic pop fasteners.
I did forget you need to lift up on the panel after pulling it loose.
You might have to destroy the panel to get to it.
kkev.7788
Sep 2, 2015 01:32 PM
