Large Bar at Front of Car
Old Oct 17, 2002 | 04:08 PM
SuperPhly's Avatar
There is a large bar that goes across the front of the car behind the bumper... it's about 1.5 inches in diameter and it has 3 uniform creases in it. I don't think it has been "hit" or "bent" but I don't think that it would be "creased".
Can someone look under thier car and check. It's not the steering linkage.. it's a bar that is welded to the frame just in front of the radiator...
If it's bent from an accident, I'll check the frame, and if the frame is straight... weld a bigger better bar under there.
Old Oct 17, 2002 | 05:16 PM
REVHED's Avatar
Hunting Skylines
It definately shouldn't be creased.
Old Oct 17, 2002 | 05:18 PM
851stgen12a's Avatar
Off riding sportbikes!
mine isnt creassed. I really dont think it should be
Old Oct 17, 2002 | 05:36 PM
Mr Project's Avatar
Well if it's supposed to be there, I've never seen one like it. I've seen maybe 10-12 different ones, exposed, on most of the different years, and I don't recall ever seeing a crease. Vertical or Horizontal? Has to have been hit at some point.
Old Oct 17, 2002 | 05:40 PM
SuperPhly's Avatar
Here's the wierd thing...
It's bent forward, not towards the engine... if it were hit from the front, it had to have bent backwards right? Otherwise, it may have been hit from the side... thus causing it to "crumple".
I hope to god there isn't any frame damage...
Old Oct 17, 2002 | 05:50 PM
Manntis's Avatar
add to cart
Might have been used to improperly tow the vehicle out of a ditch or something to dimple it like that.
Normally only a blow or a tug to the side of a length of pipe will bend it like that - an impact on the side of the car should have transferred the energy to the base of the 'pole' (for lack of a better term)and bent the frame element it's welded to.
Of course, weird things happen in collissions... but improper towing would be my bet
Old Oct 17, 2002 | 08:00 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
EVERY 1st gen I ever seen has this its part of the frame support. And it SHOULDNT be bent in any place.. Thats symbolic of it being hit, or soemthing
Old Oct 17, 2002 | 08:25 PM
RotorMotorDriver's Avatar
Seven Is Coming
Are we all talking about the same thig? The first "bar" that comes to my mind is the big steel "tube" across the front, but thats about 3" or so in diameter, wouldnt you say? He said this is only about 1 1/2" in diameter. Maybe Im thinking of the wrong thig, I just wanted to help claify things...When I get home (if its not too dark)Ill try and snap some pics and you tell me if you see it ok?
~T.J.
Old Oct 18, 2002 | 09:46 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Pics?
Old Oct 18, 2002 | 02:55 PM
SuperPhly's Avatar
Yea, that's it... about 3" in diameter... it's obviously not functional... more for structure... it's welded and quite obvious when you have the hood off...
Old Oct 18, 2002 | 04:18 PM
Manntis's Avatar
add to cart
The one under the header panel, correct?
Old Oct 18, 2002 | 05:19 PM
Seven Is Coming
Here are some pics from under my car (just ran outside and took them, lol)...This is the bar I think you are talking about...Mines not bent, and its not bent on any of the other 3 we have either.
There ya go. Hope they help.
~T.J.
Old Oct 18, 2002 | 06:05 PM
Manntis's Avatar
add to cart
Straight as a ruler on both of my cars...
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
