Spark Help
Old Oct 17, 2002 | 10:27 AM
MazdaRx7Racer4Life's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
Spark Help
OK, i still need help, here are the updates, I have no 12v to the leading coil when the key ignition is on ON, but i have 12v on my trailing. My car won't start, i have fuel, i have air, ut i have no spark, im cleaning my plugs every 2-3 starts because of all the fuel. The engine turns but it won't start.
Now its got a little warning sien inside. like if theres eomthing bad going on, As soon as i put the key ignition on ON, itstarts to beep, like if i have no oil or something, but my oil meter thingy is like off the chart.
My tach won't move at all, and sometimes when i have the battery charger on, and try to start it, it sparks somewhere around the oil filter. I used to have a kill swith hanging out of the radio when i had no radio, then when i put my radio in, i just pushed it back, but made sure it was in a place where it wouldn't go off by itself.
Old Oct 17, 2002 | 12:06 PM
silverrotor's Avatar
Although you have already stated your leading Coil Is not working, your car will still run with out It working. You'll just have half the power and Fuel Economy.
Old Oct 17, 2002 | 06:47 PM
but it won't start. at all, it on;y turns over
Old Oct 17, 2002 | 08:34 PM
bump
Old Oct 18, 2002 | 03:35 PM
buuuuuuump
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
