Anyone install the EQ/cass into a GS?
Old Oct 14, 2002 | 10:19 PM
pjr's Avatar
pjr
Mr May 2011
Folks, I may pick up this GS for sale. It doesn't have the factory stereo with joystick and a factory sunroof, options that I really like.
My question: has anyone installed the factory EQ and joystick into an 84/85 GS? How much of a pain is it? Will I need the GSL radio as well?
Thanks!!!!
Old Oct 14, 2002 | 10:37 PM
pjr's Avatar
pjr
Mr May 2011
P.S. Yes, I know the factory stereo is nothing special from a sonic perspective.
However, the nice touch controls, unique joystick control, EQ that lights up, and the champagne finish are unique features that helps make up the 1st Gen's charm...
Old Oct 15, 2002 | 10:29 AM
pjr's Avatar
pjr
Mr May 2011
Anyone?
Old Oct 15, 2002 | 10:40 AM
Directfreak's Avatar
I am a Jeeper Now.
Yes, it will work. All you need is the stock GSL stereo and the Joystick.
It's a component system so all you need to do is add the components.
Old Oct 15, 2002 | 11:29 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Your gonna need quite a bit of the harness too, the DIN cords run to the amps in the back, I beelive it all could be seperated from a junk car, but i dont see the point...
You can get a Pioneer CD player from walmart for $129, it will sound a shitload better..
Old Oct 15, 2002 | 11:30 AM
pjr's Avatar
pjr
Mr May 2011
Thanks DF... do you know if the wiring there for the joystick and EQ, or will I need to "plumb" the system?
I seem to remember some speaker install facts from many years ago in my friend's then new 1980 GS. He went to install rear speakers and found -- voila -- rear speakers already there. Turns out Mazda installed the speakers and wiring. They just weren't hooked to the head unit. Must be cheaper to build them all one way than to figure out on the line which unit gets different stereos.
Old Oct 15, 2002 | 12:44 PM
pjr's Avatar
pjr
Mr May 2011
Got it mike. Probably not worth the trouble...
Old Oct 15, 2002 | 01:12 PM
I am a Jeeper Now.
The wiring IS there. Right where the joystck goes is a connector that splits the signal to the two amps. The Joystick basically replaces this "Y" cable so you can play with the signal sound.
Many people don't know this, but the GSL's only use the FRONT output on the radio- which then gets split into front and Rear at the joystick.
The Radio has two outputs, one front and one rear though.
I recommend you forget it, get Manntis's radio system tray, and listen to Mike-P. Get an aftermarket one. Mike is biased towards Pioneer though..
Me no Likey Pioneer...
Old Oct 15, 2002 | 01:16 PM
Manntis's Avatar
add to cart
Alex and I both have the Sony MP70 CD/CDR/MP3/XM deck. Not sure if Alex has hooked his up yet but I'm running mine through Infinity speakers with just the in-deck amp and I'm happy as a clam
185 songs per CD
Old Oct 15, 2002 | 02:57 PM
85RX7GS's Avatar
I've got the stock radio that you're looking for
Old Oct 15, 2002 | 03:07 PM
pjr's Avatar
pjr
Mr May 2011
[/i]
So the signal comes from the radio to the Y connector (or joystick) and then goes to seperate amps? Where are the amps located?
Old Oct 15, 2002 | 03:18 PM
MIKE-P-28's Avatar
Yes , the amps are located in the back behind the seats , the are mounted verticaly inside the storage bins, they are silver finish, with Calrion written on them.
Sony must be better on you guys side of the world but at my shop , they suck!
Old Oct 15, 2002 | 03:46 PM
pjr's Avatar
pjr
Mr May 2011
Originally posted by MIKE-P-28
Yes , the amps are located in the back behind the seats , the are mounted verticaly inside the storage bins, they are silver finish, with Clarion written on them.
Ohhh.. very cool! This helps a ton.
Anyone have any insight on the EQ and cassette?
Old Oct 15, 2002 | 03:52 PM
I am a Jeeper Now.
They all plug into each other, only one way they fit too.
Old Oct 15, 2002 | 03:59 PM
pjr's Avatar
pjr
Mr May 2011
Ah, idiot-proof. Will suit me perfect!
Thanks again!
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
