Profec b on a T-78, what gives?
Old Oct 13, 2002 | 09:13 PM
scott(pittsburgh)'s Avatar
ok, i hooked up the boost controller just like it says:
top port of the W/G to the IN port of the stepper motor
side port of the W/G to a vac. source(tapped into the brake booster line)
the OUT port of the stepper motor to a vac. source(nipple on the upper intake manifold)
with out the B/C hooked up, i run 12psi
with it hooked up and at the lowest setting, i get 12-15psi even with the B/C off i get the same.
i tryed all the dip switches.. how do you guys got yours hook up?
right now, i have mine hooked up at stated above, and in 3rd gear, i start out at 12# and by red line, i'm at 14-14.5# and thats with the ballance turned to mild..
please let me know, thanks, scott
Old Oct 13, 2002 | 11:16 PM
Badog's Avatar
Nice meeting you, Scott. let's tune that ****** soon!
Old Oct 13, 2002 | 11:48 PM
Yes, soon i hope i put down 397hp at 13#
Old Oct 13, 2002 | 11:58 PM
Badog's Avatar
You got on the dyno! Cool! Post that sheet. I bet there are about 40 free horses hiding in there. Re-check your email again. I think your ISP ate the last email due to the extension. Sent a Zip this time.
Old Oct 14, 2002 | 06:11 AM
Buckeyeauto's Avatar
Hey Scott, nice meeting you at the dyno runs. I got there on Saterday and the lot was too full by the dyno, so I had to park the my CYM out back. I'm running about the same set up as you are. I have the low boost setting at about 10 oclock and moved the balance to about 2 oclock. I get about .75 on the PFC and it holds steady. Hey just wondering if you guys solved your lean condition above 6000rpm? I had to leave after your 2nd run. The first run scared the **** out of me when you hit fuel cut. BTW nice run at 13 pounds.
Old Oct 14, 2002 | 12:23 PM
nocab72's Avatar
03 Cobra Killer
ya, Tony, you missed his Dyno...first pull he hit 1.10 bar according to the commander. Thought he detonated, but I quickly realized it was because his PFC boost setting was on .80/.85. .85 + .25 == fuel cut.
You should have seen scott's face...it was ummm...ghost white...he was looking @ me for assurances he didn't just blow his motor...thank GOD for the fuel cut as he started going lean as hell in the 17psi range with the map he currently has.
Without a laptop (you had it), the only tools I had were the dyno WB and PIMS...so we tweaked the PIMS to give him a decent 10 - 11AFR curve and I told him to keep the boost low until we can get him back here, drop a map with enough fuel for his T78 and do some tunin!
K
Old Oct 14, 2002 | 01:54 PM
Badog's Avatar
I am tracking 3 laptops on Ebay...
Old Oct 14, 2002 | 02:09 PM
nocab72's Avatar
03 Cobra Killer
If you end up with 2, I'll buy one. The laptop we have been sharing is a work laptop, I need to return it back to the engr team sometime soon...
K
Old Oct 14, 2002 | 02:47 PM
tony, still didn't gey it, something must be messed up on my end..
Old Oct 16, 2002 | 09:09 PM
Rotary93's Avatar
Retired RX7 mechanic
Do a search under my user name.
I had this problem and re routed the vac hoses. Works beautifully!
Old Oct 17, 2002 | 09:02 PM
I tryed every way i can think of the plum this thing, and nothing seems to work.... b/c won't hold boost, go's from 10-15 at redline.... any help????
Old Oct 18, 2002 | 03:09 PM
nocab72's Avatar
03 Cobra Killer
Scott - have you read this thread?
https://www.rx7club.com/forum/showth...ghlight=profec
K
Old Oct 18, 2002 | 11:14 PM
Rotary93's Avatar
Thats the thread Im talking about...
24seven_dada
20
Nov 10, 2018 12:03 PM
