What's the point for having an Oil Catch Can?
Old Oct 12, 2002 | 08:47 AM
RecKleSs's Avatar
Adrenaline
Exclamation What's the point for having an Oil Catch Can?
Would I benefit anything from this mod?
Old Oct 12, 2002 | 09:37 AM
FourtyOunce's Avatar
you get like 50 horsepower .. jk ..
Old Oct 12, 2002 | 09:59 AM
twokrx7's Avatar
Need more sleep
Prevents oil from entering the intake during high g corners, can get a good puff of smoke and during track events can consume quite a bit of oil. There is a crank vent to the suction of the first turbo and the 93/94 cars also have a pcv which feeds the uim.
Old Oct 12, 2002 | 10:08 AM
YayeR's Avatar
english? is all this good or bad ?
Old Oct 12, 2002 | 10:45 AM
Silver7's Avatar
It is good if you don't want to blow a ton of smoke everytime you take a corner on the track. I used to have my filler neck plumbed to my turbos. After one track event I changed my setup and routed my filler neck to an oil catch can. BTW, that is a very nice one in the pic. Where can I get one of those and how much will that set me back? Bottom line is, if you are not having any problems with your current setup then don't worry about an oil catch can. I didn't need one until I gutted all my vacuum hoses when I did the haltech/non seq mod.
Old Oct 12, 2002 | 11:56 AM
jspecracer7's Avatar
1JZ powered
It's a cusco...too bad it's pre-made to fit JDM.
Old Oct 12, 2002 | 06:55 PM
stAtus's Avatar
its main purpose is to lower/vent the crankcase pressure (reduces internal drag) and to stop detonation caused by the ingestion of oil mist into the engine. the oil mist lowers the volatility of the fuel and its ability to mix with air.
Old Oct 12, 2002 | 07:11 PM
RonKMiller's Avatar
Blow up or win
That makes sense. I've always worried that adding pre-mix does this. Do you think that by adding pre-mix to the gas tank while keeping the stock oil injection system online could cause detonation? I've been adding 4 oz. of synthetic 2 stroke with every tank...??
It's a pretty low concentration.........
Old Oct 14, 2002 | 09:56 AM
RecKleSs's Avatar
Adrenaline
Hmm...maybe it still could fit on my car. Also, that girl looks so good.
Thanks for all the help guys.
Old Oct 14, 2002 | 10:25 AM
turbo4wd's Avatar
The pic on the bottom is of the Greddy catch can.. They have universal kits and the thing runs for about $100 bucks.. Nice and shiny too.. hehe
Snoopy FD
Dec 8, 2015 01:45 PM
zensokuracer001
SE RX-7 Forum
Oct 2, 2015 10:27 AM
85TIIDEVIL
Aug 25, 2015 12:09 AM
