fuel pressure regulator
Old Oct 12, 2002 | 02:37 AM
jamespond24's Avatar
Can someone penpoint to me where is the fuel pressure regulator? Do I have to take the manifold out to see it? Because I'm trying to install a nos kit and don't know where it is?
Old Oct 12, 2002 | 02:43 AM
maxcooper's Avatar
WWFSMD
It is on the firewall end of the secondary fuel rail.
-Max
Old Oct 12, 2002 | 07:05 AM
JONSKI's Avatar
5yr member, joined 2001
You can get to it without taking off the UIM (Upper Intake Manifold), but it will be a PITA. To get a clean shot at it, like in my picture, you'll need to take off the UIM and ACV (Air Control Valve).
Old Oct 12, 2002 | 09:22 AM
Jonski thank you so much you are a life saver.
Old Oct 12, 2002 | 09:29 AM
JONSKI's Avatar
Old Oct 12, 2002 | 09:44 AM
oh forgot to ask you Jonski, if I remove the UIM do I have to replace the any gasket?
Old Oct 12, 2002 | 11:39 AM
JONSKI's Avatar
The shop manual says to change it every time, but I didn't, becuase it was fairly new and made of metal. If the gasket is made of paper, then replace it. Only the '93's have paper gaskets.
Old Oct 13, 2002 | 03:19 AM
Hey Jonski is that photo take of the FPR an fd or fc? I looked at the picture and see that the whole engine is opposite. See where the fuel rail is and on top of it is a throttle, right? I thought the FPR is on the left side of the engine? I'm really confuse when I try to match the photo, it doesn't look right. Please show me more photo, so I can better compare.
thank you
Old Oct 13, 2002 | 07:19 AM
maxcooper's Avatar
WWFSMD
It is an FD. Remove the upper intake manifold (UIM) and lean over the side of the driver's side fender to get that view (firewall on the right). The solenoid rack is removed in that picture.
-Max
Rotospectre
Mar 28, 2018 03:33 PM
Snoopy FD
Dec 8, 2015 01:45 PM
