Picked up my "new" 93 R1 yesterday and have a few questions
Old Oct 11, 2002 | 03:15 PM
ExpensiveHobby22's Avatar
Drove down 700 miles to SC to pick it up. Drove it a bit then put it on the trailer and turned right back around to drive home.
Turned out to be pretty much as expected from the owner's description. I also had it checked by a rotary shop out there before deciding to buy it. The scratch in the hood turned out to be a bit bigger than I thought and the tires were trashed but whatever i guess. I still think I got a good deal.
Anyway, I've read through the archives and done searches so I'll only ask the questions I haven't been able to find there.
As I was was driving it around in SC i heard a noise that changed frequency with vehicle speed. It wasn't completely constant though like a bad tooth in the differential would be. It would also stop when I lightly pressed on the brake pedal. It sounded light, like it wasn't a massive part making the noise. Almost sounded like a cv joint in a fwd car.
Today though, it never made a sound...
Any suggestions/tests as to what it is or how I can narrow it down.
My other question is about tire size. The car has 17x9 wheels on it, 225/45s on the front and 235/40's on the rear. From what I've read in the archives a lot of people like to run 235/45's in the front and 255/40's in the rear. Is the handling that much better than just running 235/45s or slightly bigger on all 4 corners? Suggestions?
Thanks,
ray
Old Oct 11, 2002 | 03:42 PM
Toadman's Avatar
Nomad Mod
I'd check pad wear and wheel bearing play. You might be running on the pad wear sensors if it goes away with pedal pressure.
mazdaverx713b
48
Apr 21, 2016 06:45 AM
vipernicus42
Mar 7, 2016 04:57 AM
mazdaverx713b
19
Aug 29, 2015 12:30 PM
Alan777
Aug 13, 2015 02:47 AM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
