Exauhst Q's
Old Oct 8, 2002 | 06:11 AM
OtakuRX's Avatar
The Rotorheaded Geek
Question Exauhst Q's
Ok, I am currently in a state that requires a cat for anything 1980 or newer. So first what is a good cat for an RX-7 that doesn't cost an arm and a leg.
Second question, I am probably moving to Florida or Cali after I finish college, that is why I am here. Will the car pass and what all needs to be done.
PS: I cooked all the Air Pump stuff accidentally, so that is all toasted, and the carb doesn't support it anyway. So I need ways without the old air pump and all.
Old Oct 8, 2002 | 06:52 AM
85RX7GS's Avatar
A Bonez cat setup may work, but I think you might want to get an air pump off a junker and put that back on.
Old Oct 8, 2002 | 12:03 PM
RacerX7fb's Avatar
paradox
Many Spec 7 cars that I have seen use CARSOUND brand catalysts. Cost about $100, very hi-flow and supposed to clean emissions better than the stock original ones. Why this one besides cost.. the owners of the cars tell me that they will last longer than most others on a properly tuned and maintained car. Smog is a BIG deal here in Cali but hey, I love that rotary sound (:
Old Oct 8, 2002 | 12:40 PM
Gatorgunner's Avatar
when I bought my car, I checked the emissions stuff because I was going back to a state that required it.
Well when replacing some blown gaskets around the cat (cheapy ones dont last) I noticed that whoever had my car before me had drilled through the cat so it was totally cleared through.
Might be an option for you, you still keep the cat look from the outside, but you also get a really free flowing cat, and no ones the wiser.
The price is unbelieveably cheap to!
Old Oct 8, 2002 | 01:19 PM
OtakuRX's Avatar
Hmm, the Carsound sounds to be the better choice, because where ever I move I know they are going to stick the tester up my cars pipe. and FYI try going to a muffler place like Midas and ask for a quote on a new cat for a 1st gen. You will laugh your *** off at the price.
just a hint, it is almost as much as the cars cost new.
Old Oct 8, 2002 | 01:42 PM
OtakuRX's Avatar
So where can you pick up a CARSOUND cat?
Old Oct 8, 2002 | 07:54 PM
Rx7carl's Avatar
Airflow is my life
Move to FLA now so you can ditch all that emissions crap!
Old Oct 10, 2002 | 01:11 AM
Casa Grande?
Old Oct 10, 2002 | 03:44 PM
Crack Monkey's Avatar
snarf!
I use a Catco cat on my Spec RX-7. Not the best flowing, but way better than stock. It is in the stock location and the precats are replaced with striaght pipe.
The Dynomax 2.5" inlet/outlet is a good bet. On the flowbench it does as well as more expensive brands. I think (but not 100% sure) that this is the same as the Carsound, but probably costs less.
The Bonez lasts a long time and flows pretty well. Some friends use it on their Spec RX-7s. I think it is the most expensive, but already comes with flanges to fit.
The Random Tech car flows VERY well, but costs more than the Carsound and Dynomax.
tasteyspoonz
26
Mar 10, 2006 12:06 PM
iwantarx71211
14
Feb 23, 2005 12:27 AM
floor hog
13
Jun 1, 2004 10:16 AM
dirty86
28
Dec 30, 2003 03:17 PM
