okay, exhaust flanges, gaskets stuff like that
Old Oct 7, 2002 | 01:50 AM
DC350's Avatar
Rotor Head
okay, it's been a while now since i've had my race pipe installed and i keep on blowin gaskets. I'm pretty sure i have a warped exhaust flange coming off the manifold. But i made this big *** exhaust gasket, It consists of 2 normal gaskets gooped together with high temp copper silicon... its been on for 4 days. I put the pedal down today, and i heard like a ..PSHSHSHHHSHSHS everytime i hit the gas. So the gasket is blown again. Anyone have any suggestions? maybe 1 gasket with silicon?
thanks. Evan!
Old Oct 7, 2002 | 04:32 AM
DC350's Avatar
Rotor Head
anyone?
Bump, Please, watch your step :P
Old Oct 7, 2002 | 05:28 AM
Wormiez's Avatar
The same thing happens exatley to me on my car!. I also have a Bonez Race pipe.
I have blown over 4 gaskets so far!.. Just recently I warped my flange and had to re-weld a new stainless steel flagne onto it. And today after Auto X my gasket is burnt out again. ! Which causes a great drop in the low end.
Old Oct 7, 2002 | 08:00 AM
wpgrexx's Avatar
i have changed gaskets on my dual exhaust 4 times now. I started using what Canadian Tire calls their high temperature exhaust gaskets, it looks a little different, costs like 3 dollars each, usually get a summer out of a pair, the ones i have on now have lasted two summers, but will replace when hibernating for the winter
Old Oct 7, 2002 | 02:14 PM
DC350's Avatar
Rotor Head
thats cool....I'm going to get a normal one. And then i will put copper silicon on it. I will check out those from canadian tire. I guess i will have to get the manifold shaved off, to get rid of the warped flange.
Old Oct 7, 2002 | 02:17 PM
DaleClark's Avatar
RX-7 Bad Ass
First off, never use RTV on exhaust gaskets - that's probably half the reason you're blowing them out. Two flat surfaces with a quality gasket in between and you're golden.
The RTV makes the "weak link" if you coat an exhaust gasket with it - NEVER use any sort of coating on exhaust gaskets.
Dale
Old Oct 7, 2002 | 02:25 PM
Xentrix's Avatar
Kill Bear
the guy that put my header on used some special drag race high temp goo for a gasket. I've had that setup for 1.5 years with no problems. I don't knowwhat it was but it was rated to like 1600+degrees
Old Oct 7, 2002 | 02:37 PM
DC350's Avatar
Rotor Head
mine "high temp" like 700 degress. I guess they dont know the heat of the rotary.
SHould i get dual gaskets and put nothing on them? Or just a single again...
FD7KiD
15
Feb 26, 2021 10:12 PM
Kyo
Apr 13, 2019 09:24 AM
FD7KiD
Aug 17, 2015 11:50 PM
