taking off the thermal reactor
Old Oct 6, 2002 | 01:06 PM
RotaryMotorDisorter's Avatar
I got my new RB exhaust system and now im wondering what you guys do to get the thermal reactor off. Its hard to get a wrench or socket in. Who designed this lunker!
Old Oct 6, 2002 | 01:53 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
There's no easy trick that I'm aware of, just have to work at it with an open-end wrench. Swearing seems to help me. Good luck with it! Oh, by the way, what year is it, and which RB header are you using? -WG
Old Oct 6, 2002 | 04:12 PM
Manntis's Avatar
add to cart
Exhaust components tend to sort of 'weld' themselves into place, especially up near the engine where they're the hottest.
A lot of liquid wrench, elbow grease, blood, sweat, and tears helps lube them up.
Tips:
-Don't use a socket when breaking torque; it just breaks the rachet.
-See if you can get a box end wrench in there, instead of an open wrench.
-If you use a wrench, try to push the wrench to loosen the bolt rather than pulling towards you. This way you can push with an open hand, and if you slip you just end up slapping part of your car as opposed to stabbing the knuckles of a fist with a forward slip on something or slashing the meat of your lower thumb or wrists with a back slip...
Old Oct 6, 2002 | 09:31 PM
thanks
Ill be doing all this tomarrow so wish me the best. Now i can finally drive around knowing who i am and where im at (exhaust fumes get to me) LOL. I went all out and baught the RB street port exhaust system if anyone cares. Hope it sounds as nice as people tell me. I figured buying this street port system would inspire me to actaully do a street port.
Old Oct 6, 2002 | 10:28 PM
peejay's Avatar
Old [Sch|F]ool
Easiest way without the Special Tool is to remove the intake manifold first.
I was able to yank mine with the intake manifold on, but the engine was out of the car, I used many different tools (crow's foot, several different offset box wrenches, a 15mm swivel, a healthy supply of expletives, half a pack of smokes) and it took about an hour or two. Wouldn't dream of trying that with the engine in the car due to some of the angles I was working at
Old Oct 7, 2002 | 12:36 AM
crazy
might have to grind down a cheap socket. Its real close to fitting on the nut but just not enough. Ill let ya know what happens.
Old Oct 7, 2002 | 11:02 PM
did it
To anyone who went through what i just did installing this exhaust system, my heart goes out to you! It was hours of hell. It payed off though, it feels and sounds great.
Old Oct 9, 2002 | 12:04 PM
i would take a drill to it. That is what i did
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
OCDHerb
Sep 9, 2015 02:19 PM
OCDHerb
Sep 7, 2015 05:41 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
