Found Wierd Ass Problem, How to fix?
Old Oct 5, 2002 | 08:28 PM
NRA T2's Avatar
Found Wierd *** Problem, How to fix?
when I check the timing on my trailing plug #2 I can't even see the timing marks on the pulley but I can on the trailing plug #1, this is screwing up my idle and means that one plug is firing @ a really weird spot, so what is wrong and how do I fix?? Someone please help me
Old Oct 5, 2002 | 08:37 PM
bkapold@aol.com's Avatar
You should have two marks on that pulley.....The L-1 is the yellow mark....Just time it by that and don't worry about the other....Your L-1 coil is closet the battery mounted ont driver shock tower...
Old Oct 5, 2002 | 08:38 PM
NRA T2's Avatar
by the way the t2 plug is sprarking and the timing light is flashing
Old Oct 5, 2002 | 08:40 PM
NRA T2's Avatar
I have 4 marks (aftermarket pulley) the timing is right on 3 out of 4 wires how is this possible?? my t2 plug is firing EXTREMELY advanced or retarded
Old Oct 5, 2002 | 08:44 PM
Are the wires and plugs new? There might be a problem there...Did you mess with your timing because you thought it was off or did you just mess with it because?? just curious why your having problems.....
home : bkapold@aol.com
Old Oct 5, 2002 | 08:46 PM
NRA T2's Avatar
was checking to see why my idle is rough and this would explain it, this is the only reason I have found and yes the plugs + wires are new
Old Oct 5, 2002 | 08:49 PM
Scott 89t2's Avatar
SOLD THE RX-7!
well the T2 fires 180 off of T1... I doubt you have marks for both??
Old Oct 5, 2002 | 08:51 PM
NRA T2's Avatar
but the l1 and l2 wires have the same timing
Old Oct 5, 2002 | 09:35 PM
NRA T2's Avatar
bump
Old Oct 6, 2002 | 01:46 AM
Keith's Avatar
Keep looking, what you describe is normal, only the T1 plug wire will line up to the mark. Yes, L1 and L2 both line up to their mark, but that is because the leading plugs use a waste spark system, that is both plugs are fired by the same coil at the same time. So either wire will illuminate the mark.
Whatever your problem is, it is not ignition - you just verified that everything is ok in that department. Check the usual - vacuum leaks, TPS, temp sensors etc.
Boriquaguerrero
110
Dec 22, 2025 11:03 AM
Th0m4s
Feb 26, 2019 02:04 AM
hoofhearted
NW RX-7 Forum
23
Feb 2, 2019 11:50 AM
Microtech
30
Apr 23, 2016 06:37 PM
tsmith94FD
Aug 16, 2015 05:41 PM
