T2 engine swaps
Old Oct 5, 2002 | 08:08 PM
T2 engine swaps
Hey,
Will the 89-91 T2 engine be a direct fit for into an 1988 T2 body?
thanks,
Hakan Uras
Old Oct 5, 2002 | 09:06 PM
Scott 89t2's Avatar
SOLD THE RX-7!
no...
Old Oct 5, 2002 | 09:08 PM
Icemark's Avatar
Physically yes, but...
You will need to change the 89-91 front cover so that it supports the mechanical OMP of the series 4 motors, as well as there are some electrical harness issues.
Old Oct 6, 2002 | 12:06 AM
87GTR's Avatar
block of the omp and run premix
Old Oct 6, 2002 | 12:09 AM
I am planning on doing the same swap, so any info is great. Thanks guys.
Ron
Old Oct 6, 2002 | 05:47 PM
What type of electrical harness issues are we talking about??
Old Oct 6, 2002 | 06:06 PM
chris_stampe's Avatar
If you use the s5 ecu you cant use your s4 gauges and all that ****. If you use the s4, you have to swap the front cover on the engine and i believe intake manifolds. But yeah it will bolt right in the exact same. There are probably a bunch of small issues you may have to address like sensors and what not.
Old Oct 6, 2002 | 08:05 PM
Icemark's Avatar
wire lengths, no EGR valve for series 5, some wire connections (like the alt).
Old Oct 6, 2002 | 08:51 PM
Is there a good write or site on what would have to be done to drop an S5 in an S4?? Thanks guys,
Ron
Old Oct 6, 2002 | 09:41 PM
600HP CLUB's Avatar
will the series 5 block work on a series 4? i'm talking about everything electrical (tps..etc..) everything mechanical OMP, throttle body, intake manifold, intercooler...........
-mike
Old Oct 6, 2002 | 10:43 PM
Gen2's Avatar
if you plan on doing a S5 into a S4, just use the s4 wire harness most sensors are the same however switch over those that dont plug up, and use the s4 injectors, front cover with OMP, TB, coolant necks, water pump, and altenator..
HTH
-AL
Old Oct 6, 2002 | 11:26 PM
FC Drifter's Avatar
Damaged Little F*cker
my 87 T2 has an 89 j-spec. i did all the swap stuff. the actual block itself is the same. but the OMP is different(swap front cover), TPS is different(i swapped upper and lower intake manifolds but heard you could just swap throttle bodies), when you swap the front cover the 89+ alt and water pump wont fit anymore so that has to go back to 87-88. i dunno about P/S, my car doesnt have it. if i can remember more ill list it here.
Azevedo
26
Mar 1, 2019 09:19 PM
maikelc
Aug 24, 2015 11:04 AM
elfking
Aug 19, 2015 09:48 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
