idle
Old Oct 5, 2002 | 06:59 PM
Vohaul's Avatar
idle
ok ok,
so im drivving to work...suddenly car dies ...and wont idle at all....fires right back up.....but have to keep on gas in order to kep running......
so i pull over...(to see if all spark plug wires and coil wires are still attached......i touch a coil wire and got a huge jolt.....(the car had decided to somewhat idle by this point..so it was running...
should i be getting a shock wen touching coil wies when the car is running?..or is this a sign of a bad coil wire/ park plug wires.....
thnks
Paul
Old Oct 5, 2002 | 07:28 PM
851stgen12a's Avatar
Off riding sportbikes!
I would replace the wires, typically that means the unsulation is breaking down. could cause an arch.
I grabed the coil wire once when I was 16, havent done it since. My arm hurt for a week.
Old Oct 5, 2002 | 09:47 PM
REVHED's Avatar
Hunting Skylines
It's probably a good idea to replace the wires but I doubt this was the cause of engine stalling. Judging by the fact you had to hold the throttle open to keep it from dying I'd say the carb was flooding. Probably some debris caught in the needle and seat or something like that...
Old Oct 7, 2002 | 03:30 AM
Talking
What's it, like 10000 Volts going through the coil wire to the distributer? Getting shocked by that isn't that shocking, pun intended.
I always steer clear of all the distributor wires when its running. Experience is a great teacher! When for instance you are holding a spark plug wire with the plug or a coil wire out to see if there is a spark, always use an insulated plier, or ZAP
Your problem sounded carb related....
Old Oct 7, 2002 | 04:38 AM
peejay's Avatar
Old [Sch|F]ool
You don't always learn.... One time we were trying to get a recalcitrant lawnmower to start. It was flooded REALLY badly. So, I pulled the spark plug out, held the coil wire away from the engine with one hand, held the throttle wide open with the other, and my friend gave a few good yanks with the starter cord.
Think about that, 'cos I sure didn't. One hand on the spark plug lead, the other one grounded to the engine.
Then we cross threaded the spark plug hole in the head after yanking the plug so many times. Kinda wedged the plug back in (cross threads are better than no threads!) and the thing started! With puffs of flame shooting out where the spark plug wasn't sealed to the head properly. Damndest thing I ever saw. I'm really surprised what with all the screwing around with lawnmowers that we did, that we all still have all of our feet and hands
That reminds me... NEVER look at a fan with a timing light. The fan will appear stationary. Until you absentmindedly try to rest your hand on it. >>>ZING!!<<< Don't worry, I still have all seven fingers!
Back to your problems. Really bad plug wires will arc like that. Wires are cheap enough, just change 'em out. If it was particularly wet outside when this happened, it could have been the whole trouble. Bad wires love wet weather, it gives them the opportunity to find a much easier path to ground through the insulation! (Or the poor guy who happens to grab the wires... )
Old Oct 7, 2002 | 01:25 PM
sweetege's Avatar
bzzzzzzzzzzzzz
yea I would think that wouldn't feel good peejay.
Old Oct 7, 2002 | 10:30 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
**** I kinda like it, gives me a good buzz. When I dont have bad plug wires, Im sure to carry a 9v battery inmy pocket for those times I need a good jolt via my tongue LOL
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
Jmpabon93
Sep 30, 2015 04:57 PM
