What should stock oil pressure be?
Old Oct 4, 2002 | 05:31 PM
AreExSeven's Avatar
Huh?
Just started my car up to let it run solid for a few hours to break the engine in.
What should my stock oil pressure guage read for now? Car is all stock with new motor.
Thanks guys!
Need a quick response!
Old Oct 4, 2002 | 05:37 PM
NRA T2's Avatar
@ 2000 rpm mines @ almost 70, that's where it's suposed to be according to Haynes, not sure about idle I think maybe 35 or 40
Old Oct 4, 2002 | 05:42 PM
AreExSeven's Avatar
Huh?
Oki.
Thats where mine is. Between 30 and 60 somewhere.
Old Oct 4, 2002 | 06:36 PM
Suds7's Avatar
Mine never goes above 30 at idle and 45 running whats wrong?
Old Oct 4, 2002 | 07:04 PM
biorotary's Avatar
what grade oil are you using?
with 20w50 you ought to see about 45 at idle and a little over 60 @ 2000+ rpm
Old Oct 4, 2002 | 08:05 PM
Scott 89t2's Avatar
SOLD THE RX-7!
should be around 60-70 at 3000rpm. idle is normaly around 30. mines at 12... < shugs >
Old Oct 4, 2002 | 09:02 PM
Ni5mo180SX's Avatar
White Comet
Im at about 35psi at idle and hit about 70psi 2800RPM+ using Castrol 20-50w. Using 10-30 before left me about 10psi lower on the above mentioned situations.
Old Oct 4, 2002 | 10:03 PM
HWO's Avatar
HWO
inteligent extratarestril
you are merely guessing if you are getting your readings off the stock guage, only way you can truely tell your oil pressure is with an aftermarket guage
Old Oct 4, 2002 | 10:07 PM
AreExSeven's Avatar
Huh?
Ya, not trying to be totally acurate, but the stock guage gives me some idea for now.
Old Oct 5, 2002 | 12:49 AM
88 SE's Avatar
Replace the stock sending unit or get an aftermarket gauge.
After 15 years of oil, heat, and other things, the stock gauge tends to be pretty innacurate unless replaced.
andyvideopro
Aug 20, 2015 10:55 AM
Clacor
Aug 14, 2015 09:17 AM
