Found my boost problem! :)
Old Oct 4, 2002 | 01:57 AM
gz91rx7's Avatar
Well for anyone who has read my old threads about my boost problems I finally found it!
The nipple on the top of the turbo was WAAAAYYYYYY loose and it just spun around.
So I put some JB weld on it and woooohoooooo I have 10psi!
First gear is still only like 5-6 psi but it spools much faster and 2nd gear actually has some pull now!
I have yet to get it out so that I can really open it up but I am very happy that I found my main problem.
I did notice that in 3rd gear in higher RPM's my boost drops. I dont know why that is happening but I havent search yet.
So I would like to thank Scott89T2 and BlueTII for all of your help and time. It is VERY appreciated.
Josh
Old Oct 4, 2002 | 07:59 AM
Josepi's Avatar
Despise Enmity
Re: Found my boost problem! :)
Josh
Stock turbo and engine?
Old Oct 4, 2002 | 09:45 AM
gz91rx7's Avatar
The engine was rebuilt about 7k ago.
The turbo is a garett T04b hybrid with a ported HT-18 wastegate.
Old Oct 4, 2002 | 11:24 AM
Josepi's Avatar
Despise Enmity
Did they make any changes to the turbine? Also, do you have a boost controller?
Old Oct 4, 2002 | 12:04 PM
Fox4Life's Avatar
sweet, good job josh. i had the exact same problem not too long ago. that little damn L shaped hose was blowing off everytime i tried to go into boost. where you the one with the red TII with the MSD ignition box sitting on the fan shroud at the MI lansing meet? just trying to put names/faces with cars. thanks
Jerry
Old Oct 4, 2002 | 12:23 PM
LS1FC's Avatar
LSX7
Hey this sounds like a problem i may be having. I have checked just about everything but still cant seem to cure my 5-6psi boost problem...I have replaced the intercooler hoses, checked the duty solenoid, checked for proper operation of the wastegate with a pressure gun but still the car wont boost past 5-6psi...I also borrowed a friends N370 ECU...Any advice or help guys.
Old Oct 4, 2002 | 12:47 PM
95R2-89TII Ground Zero's Avatar
Banned
Josh
Thanks for saying thank you to me, not that my ideas were any good, but I had to at least hear you complain about this **** to me all the time...LOL....and hey, I let you use my garage, I see how it is.
Old Oct 4, 2002 | 01:46 PM
Scott 89t2's Avatar
SOLD THE RX-7!
hmm... that line came off on me once. and I hit 15psi in 1/2 a sec... cause that means the wastegate stays 100% closed.
I guess with it leaking. there was still enough pressure to open the wastegate, while bleeding boost at the same time.
Old Oct 4, 2002 | 02:25 PM
that 90 degree nipple spins around on my turbo as well. I have a boost controller now and I was putting anew vacuum line on that nipple and it just spun around. I take it this is bad then?
Old Oct 4, 2002 | 02:49 PM
NRA T2's Avatar
what nipple are you talkin bout
Old Oct 4, 2002 | 03:02 PM
LS1FC's Avatar
LSX7
Yes I too would love to know what nipple you are talking about.
Old Oct 4, 2002 | 03:09 PM
Dyre's Avatar
Your Opinion is Wrong
The one fitting on the compressor housing.
Old Oct 4, 2002 | 05:19 PM
NRA T2's Avatar
how the F would it spin on my turbo it's one solid piece ?
Old Oct 4, 2002 | 08:54 PM
LS1FC's Avatar
LSX7
Does anyone have pics of this nipple, I have no idea where it is located on the stock turbo? Is it common for this thing to break and then leak boost?
Old Oct 5, 2002 | 01:10 AM
slidingsky's Avatar
**** I just replaced all the vacume lines trying to find the boost leak. I havent started the car yet but now I have a better idea where to fix. Mine spins freely. Thanks for noticing.
sky
Old Oct 5, 2002 | 01:15 AM
Rpeck's Avatar
What R U thinking self?
I assume this is the plug he is talking about. Notice in this pic there is no plug on the turbo yet, and this is a T04 housing ... but this Pic should give you a idea of what to look at.
Correct me if I'm wrong
Old Oct 5, 2002 | 01:31 AM
gz91rx7's Avatar
Rpeck you hit it right on the head! My housing is alittle different but that is the exact nipple that I was talking about. Mine is alittle higher but that is it!!!
Old Oct 5, 2002 | 09:06 AM
Well, I guess I'll go jbweld that little bitch to stop it from spinning as well.
To the guy who said it was one piece - on the stock turbo, there is a metal 9 degree elbow which connects to a short ~2 inch piece of vacuum hose, which connects to a long round steel pipe which goes around the compressor housing to the bottom where I believe on a stock system it has a vacuum hose on the end which connects to the wastegate actuator (little bronze top hat looking thing).
I have a MBC installed so I connected straight from the steel elbow nipple on the compressor housing to the MBC, then right down to the wastegate actuator.
Old Oct 5, 2002 | 05:12 PM
I have just been told that this 90 degree nipple on the compressor outlet should be able to spin. It should not be leaking. I decided against jbwelding mine tight and ended up finding my intake leak somewhere else anyway. Woohoo... got my vacuum back and my boost. sweet!!!
Queppa
Nov 18, 2024 03:47 AM
alphawolff
Nov 17, 2015 05:57 PM
