rotor wont come off.
Old Oct 2, 2002 | 06:31 PM
I'm trying to change my brake rotors because the ones on my car are 30 thousanths to thin
however, I can't get this rotor off. I've tried using liquid wrench, prying with screwdriver, and hitting with rubber mallet, but It just won't even budge.
anyone have any suggestions??
Old Oct 2, 2002 | 06:33 PM
Silkworm's Avatar
Has been.. hangin' around
Assuming you've removed the screw, and removed the caliper (sorry), bust out a bigger hammer. I hit one side, then the opposite side, working the rotor off.
Alternately, get a propane torch and heat up the rotor hat, but be careful of the grease in the hub, you might get a small fire start if you aren't careful
PaulC
Old Oct 2, 2002 | 06:35 PM
how about a heat gun???
Old Oct 2, 2002 | 06:39 PM
Silkworm's Avatar
sure, that might help, set it on it's highest heat, and move it closely around the hat area.
PaulC
Old Oct 2, 2002 | 06:42 PM
Roy James's Avatar
My cars louder than yours
I like the hammer idea... but... look who your asking.
Old Oct 3, 2002 | 12:30 AM
take it to a machine shop and have them press it out like nappa or something. You dont want to ruin that hub they are very pricey
Old Oct 3, 2002 | 12:32 AM
Cheers!'s Avatar
Former Rx7 *****
get a big hammer
Old Oct 3, 2002 | 01:14 AM
Rs4Racer's Avatar
i think there is two holes in the rotor that are meant for this.
alls you have to do is get some bolts and screw them in there. viola your rotor just pops right off.
try this before you go hammering away. thats actually what there there for.
Old Oct 3, 2002 | 01:48 AM
hIGGI's Avatar
holes in rotor for removing are only on rear rotor if i remember correctly.....
Old Oct 3, 2002 | 02:11 AM
Rs4Racer's Avatar
in the rear there are screws.
Old Oct 3, 2002 | 10:38 PM
Henrik's Avatar
Buy a deadblow hammer. 1-2lbs will be sufficient and give it a couple of good whacks from the back side moving around the rotor. Don't use a regular steel hammer, it will just bounce.
Henrik
87TII
ZacMan
Sep 19, 2015 09:20 PM
Monsterbox
Sep 11, 2015 03:29 PM
Ian_D
Sep 6, 2015 10:38 PM
