stuck ports!
Old Oct 2, 2002 | 12:34 PM
stuck ports!
ok i got a 89 gxl that im fooling around with for a friend. it is slow as ****. the ports dont open,neither does the vdi. is it ok to wire the ports,vdi open on a 89. i know i can on my s4 but im not sure about a s5. and if so which way do i move the ports,vdi to make sure there open all the way?? thanks
Old Oct 2, 2002 | 12:43 PM
SureShot's Avatar
Seduced by the DARK SIDE
The actuators push to open on the s5. Usually it's not the sleeve the sticks, it's the rod, where it passes into the LIM.
Old Oct 2, 2002 | 12:48 PM
so do the ports go the left one goes left and the right one goes right?
Old Oct 2, 2002 | 12:49 PM
this is looking str8 at if from the passenger side
Old Oct 2, 2002 | 01:01 PM
SureShot's Avatar
The internal sleeve opening is turned upward when closed, and turns inward and downward to open.
banzaitoyota's Avatar
What Subscription?
Get Roy James to help you out!
Old Oct 2, 2002 | 02:40 PM
um ok?
so both should be down to open?
Old Oct 2, 2002 | 03:48 PM
Mobius's Avatar
Ports
I'm not sure how the set up is for vdi, but i think your ports open when the actuators are up. They open as a result of backpressure.
If you wire them to the open position your off the line acceleration will suck. If they are stuck, get new ones.
Mine were stuck open and my off the line time was horrible.
When you say Vdi won't open, are you talking about the cylinderical port that's in the middle of the manifold.
If that's not opening either, my conjecture is maybe the entire system that is operated according to the back pressure is shitting out somewhere. Maybe your air pump is leaking or something?? The air pump is that pully driven thingy-ma-bob that has a hose which is fed back (if memory serves me) right between the two actuators. My suspicion is, if you don't have that air "pumping" pressure correctly, that might be part of the problem.
That is my conjecture.
Good luck.
Old Oct 2, 2002 | 04:30 PM
silverrotor's Avatar
Re: stuck ports!
Good Thread that should answer your question(s). https://www.rx7club.com/forum/showth...light=argument
Old Oct 2, 2002 | 04:36 PM
sunshine's Avatar
Just fix the friggin things...actuators are easy enough to get if yours are shot. On an S5, the push to open, rotating the sleeves towards counterclockwise (front) and clockwise (rear).
Just fix it, the car will run like *** with everything wired open.
Old Oct 2, 2002 | 04:44 PM
dre_2ooo's Avatar
Uhh... the rods extend UP when OPEN. this should rotate the sleeves so that the opening is into the engine .
They are operated by the airpump and can get stuck closed after as little as TWO WEEKS of non-use. The VDI moves DOWN when attatched to the engine, in car. Also, the airpump.
Getting these bastards unstuck is a REAL PITA. You usually gotta take off the manifold and then you can rotate it by hand. I recomment outting lots of oil around the sleeves and WD-40 on the linking arms. make sure you take it past 5500 RPMs everyday to keep the VDI and 6-ports working
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
Josh83rx7
Sep 15, 2015 10:23 AM
