Hurley's new corner seals!!!!!
Old Oct 2, 2002 | 12:13 AM
Angel Guard Racing Team's Avatar
Here you go guys:
Hurley Rotary
Old Oct 2, 2002 | 01:13 AM
Icemark's Avatar
cool design, but I wonder about build up in the springs over time.
I sure like that it is centered though... too bad they were not available when I was rebuilding the Jspec for use in my car.
Old Oct 2, 2002 | 06:22 AM
banzaitoyota's Avatar
What Subscription?
Of course they come out After I get my new engine!
Old Oct 2, 2002 | 10:37 AM
jimmyv13's Avatar
Round&Round not Up&Down
cool idea. I wonder, too, how the springs would hold up with carbon build-up. Would these work better with running premix instead of the MOP?
Is that price of $120 for a set of 3 or each?
Old Oct 2, 2002 | 11:12 AM
amemiya's Avatar
nice and I just put my motor back together well I guess I will have to wait 15,000 miles.
Old Oct 2, 2002 | 11:48 AM
vaughnc's Avatar
knowledge junkie
New Improved HME Design
Traditional Design
Old Oct 2, 2002 | 12:00 PM
Roy James's Avatar
My cars louder than yours
Exactly what is wrong with the "traditional design"? I hardly hear of someone blowing a corner seal.....
Old Oct 2, 2002 | 12:10 PM
peejay's Avatar
Old [Sch|F]ool
I'd imagine the Hurley design would be more prone to cracking (similar to the mazda "solid" seals) due to the thinnest section being significantly thicker.
I too was unaware that there was any problem with the "traditional" Mazda corner seals...
Old Oct 2, 2002 | 12:40 PM
Traditional design does not push evenly and sometimes get stuck. I've seen plenty of broken corner seals.
Old Oct 2, 2002 | 06:57 PM
HWO's Avatar
HWO
inteligent extratarestril
hurley cnr seals would allow probably another 1mm to be taken out of the back of the port on a street port, however, on a bridgey, bridge would have to be closer to the outside meaning a thinner eyebrow would have to be used. if you are wondering how i come to those conclusions, its because the black rubber piece which goes in the middle of the cnr seal is normally what you use for the back edge and bridge thickness
Old Oct 2, 2002 | 07:48 PM
We don't use rubber inserts on factory corner seals at all on our drag RX-7. They don't do a thing we just leave the hole blank... Anyways we do not use bridge ports. And no our engine is not taken apart after every event our current engine has over fifty (50) 8 second runs and still going hard. The part that pisses everybody off is that we use 3 piece Mazda factory apex seals when everyone else is using Iannettis... Methanol/Turbo rules!!!
Old Oct 2, 2002 | 09:29 PM
Liquid Anarchy's Avatar
We come with the Hardcore
The only thing I can see is there's less of a surface holding the apex's sides. I'll stick with my "traditional" seals.
Old Oct 2, 2002 | 10:45 PM
Roy James's Avatar
Old Oct 2, 2002 | 10:57 PM
mikeric's Avatar
FB=OS Giken LSD
I'm curious to see how these work. Have there ben any long-term tests on them?
Old Oct 3, 2002 | 12:46 AM
They are new so I don't know. Anarchy has a very good point here it looks like there is less surface touching the seal Hmmmm... I'll e-mail them with this question...
Old Oct 3, 2002 | 01:12 AM
HWO's Avatar
HWO
WAY TO GO!!!!!!
Old Oct 3, 2002 | 01:37 AM
The part that pisses me off is that my car gives me more pains than the drag car. Give me a haltech a good engine and some $$$ I can make it run. Give me factory ecu and I'm f_u_c_k_e_d...
Old Oct 3, 2002 | 02:34 AM
RETed's Avatar
That's the craziest thing I've ever heard...
They do make "solid" corner seals that have no rubber insert.&nbsp The rubber insert increases sealing.&nbsp If you don't put this rubber plug back in, you very little support of the apex seal at the ends - usually where a lot of stress happens.
The Hurley corner seal looks like it makes the design stronger by leaving a thicker "bottom", as I've seen corner seals crack at this thinnest part.
-Ted
Old Nov 30, 2002 | 05:33 PM
Astro's Avatar
i was at the local rotary shop the other day and they took a factory mazda corner seal and broke it with the index finger and thumb.
Then i took a pair of pliers and couldnt break the hurley corner seals and i was squeezing pretty damn hard.
Snook
Oct 8, 2015 10:09 PM
James Knox
Oct 5, 2015 07:56 AM
