Struts Question
Old Oct 1, 2002 | 08:33 PM
Digi7ech's Avatar
I break Diff mounts
Struts Question
Well I am getting pretty pissed off at my car.
First it starts running 18.2's and now this.
Well, I've gone to 3 shops so far.Every single one says they can install 2 new front struts in my car. Either my Koni Adjustables or Stock ones.
I then take my car down to them and then a half hour later they call and tell me they can't install 'em.
They say they would have to weld on new somethings and cut stuff.
The price that they are quoting me is around 800+ for Koni or Stock.
I have a 88 SE and there's no way I am spending that much on it.
Do all of our cars have to have this done or is it just my piece of ****?
Old Oct 1, 2002 | 08:39 PM
NCsublime's Avatar
I've got some Tokico 5-way adjustable struts with some RB 1" lowering springs and RB front and rear stabilizer bars, and I didn't have any problem putting them on myself. Of course, the springs were already mounted on the struts, which made it extremely easy. I don't know what the problem could be. I own a 91' NA FC.
Old Oct 1, 2002 | 08:48 PM
Digi7ech's Avatar
I break Diff mounts
The struts I bought where the 150 Each Koni Adjustables from RX7-Store. They came without any mounts on them.
Old Oct 1, 2002 | 08:59 PM
FPrep2ndGenRX7's Avatar
If they have to weld or cut don't let them do it. You either have the wrong struts or the shop mechanics are extremely incompetent. They should only need a spring compressor as the rest of the install is all nuts and bolts.
Old Oct 1, 2002 | 09:19 PM
Digi7ech's Avatar
I break Diff mounts
These are the ones I have
They say they require modification to get them in.
Old Oct 1, 2002 | 09:22 PM
Digi7ech's Avatar
I break Diff mounts
hmmmm.
This is the pic from The place I got the struts. RX7store.net
I dont know if its just a example pic or thats what their supposed to be.
Old Oct 1, 2002 | 10:13 PM
Wankel7's Avatar
Haven't we ALL heard this
If you install the Koni yellows in your 7 in the front you DO HAVE TO CUT. Welding is not in the directions and might be something to scare you away cause they are lazy.
The fronts are cartridges basicly. You will cut the top off of your stock struts. Remove the guts and then drop in the new ones.
Check out my webpage for a write up
http://pws.gamewood.net/~mb800/struts/struts.html
I like the stuts a lot. You have infite adjustments. Not five clicks.
James
Old Oct 1, 2002 | 11:17 PM
Silkworm's Avatar
Has been.. hangin' around
James, excellent write up.
PaulC
Old Oct 2, 2002 | 06:52 AM
I forgot about the Koni's being a drop in. Sorry about that.
_Tones_
May 25, 2021 05:37 AM
