ever had this?
Old Oct 1, 2002 | 03:34 PM
damon's Avatar
ever had this?
OK, my car seems to loose all power at 5000 rmp in third and fourth gear (it will spit and sputter and try to choke out). Also, when driving slow it will kick a little (as if it is loping), and it just started backfiring upon decel and shutoff.
I noticed that my leading coil was arching on itself so I changed it but it still archs (from the screws to the center where the plug goes to the dizzy. What is causing the arch, and could that be my loss of power?
I have my fuel reg maxxed to 5.5 on the gauge and the fuel stays at the halfway point (cheap reg).
Im at a loss and my top speed is only 95 mph and I know it has more in it.
Im going to re-check timing, fuel delivery, connections, air/fuel mixture tonight.
O, it a stock 85 12a with a rebuild nikki, rb header, no rats nest cat or smog pump, air/oil cooler, new plugs, wires, dizzy cap, rotor, air filter, fuel filter, and accel super coil on leading
peace
Old Oct 1, 2002 | 04:18 PM
REVHED's Avatar
Hunting Skylines
Please don't tell me you still have the stock fuel pump?
Old Oct 1, 2002 | 04:20 PM
damon's Avatar
no, got it from napa. puts out 10psi unregulated, but I dont have a pressure gauge so I dont know exact psi with the regulator.
peace
Old Oct 1, 2002 | 04:40 PM
someone82's Avatar
Sounds like you have a leaky coil wire for the leading coil. For that just get a new set of wires.
matt
Old Oct 2, 2002 | 07:59 AM
damon's Avatar
just got new wires, put them on with the new coil still cross firing
peace
Old Oct 2, 2002 | 08:29 AM
Rx7carl's Avatar
Airflow is my life
Put dielectric grease on your plug wire/coil wire boots. Check your cap/rotor and plugs for condition, and make sure the engine/body ground is good.
Old Oct 2, 2002 | 08:44 AM
damon's Avatar
used silicon dielectric grease on all wires (coils, dizzy, and plugs) and all new 4 ga wire for power and ground and also added two grounds over stock (one on inner fender, one on firewall, one at the starter and one on top of the motor).
peace
Old Oct 2, 2002 | 09:34 AM
Rx7carl's Avatar
Airflow is my life
SOunds like high resistance somewhere in the circut. Bad plug? bad cap/rotor?
Old Oct 2, 2002 | 09:56 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
when I broke my dizzy rotor (battery slid into it) the trailing would arc. start repacing ignition stuff, it good maintinece anyway
Old Oct 2, 2002 | 10:05 AM
peejay's Avatar
Old [Sch|F]ool
in my experience the Purolator pump you get from parts stores will peak at about 130hp, and that is if you run with no return line. You're probably still fuel-starving.
On the other hand, try removing the trailing lead from the distributor cap (ground it to a strut bolt or something to keep the coil from self destructing) and go for a quick drive. If the problem goes away, then your trailing timing is too advanced and the bucking you are feeling is detonation. It doesn't quite feel the same as how it feels on a piston engine.
Old Oct 2, 2002 | 10:30 AM
damon's Avatar
yea I was just reviewing yaws site and he suggests a 10 deg split. The shop that I took the rex to set leading on the first mark and trailing on the second (thats a 20 deg split. Im going to adjust tonite and Ill keep ya posted. thanks for all the help everyone.
peejay- could that be the cause of the coil arching Im experiencing?
peace
Old Oct 3, 2002 | 01:21 AM
Gatorgunner's Avatar
Hey if that doesnt work, switch around your ignitors and see if the problem persists.
I know it sounds dumb, but i had the same problem. I switched the ignitors around and the car runs just fine now.
Go figure!
