Points in window switch
Old Oct 1, 2002 | 01:05 AM
HIMNI Racing's Avatar
Rick James
Question Points in window switch
Does any body know if its possable to repalce the points in the drivers side window switch? If not is it possable to put a good soder bead on it and have it work and last? Any nput would help lots. Thanks
Old Oct 1, 2002 | 01:23 AM
2ndGen.rocket's Avatar
Ho's and Cadillac Doors
yeah, my window switches seem to be dying
Old Oct 1, 2002 | 01:29 AM
Rick James
We just got home from Wal-mart and the window would not go up. Well this being Florida and all we could have a rain storm right now..............or ................now ...not good. It;s been messing up and Mazda trixs wants $130 for a new one.
Old Oct 1, 2002 | 07:12 AM
Sod's Avatar
Sod
mine just went out i cleaned them w/ sandpaper they work now
Old Oct 1, 2002 | 03:07 PM
Rick James
I cleened mine with a file made for cleening points in washer timers,shot it with some con. cleener, hit it with some air,relubed it and it worked aswell. but, two of the points are almost gone and will not last long. some help with my 1st ?
Old Apr 18, 2007 | 09:24 PM
tarmac_terror's Avatar
Glowing brake disks
I thought about doing that too, but after talking to an electrical engineer friend of mine he explained that it wouldn't be a good idea to put a solder bead on the contacts... Solder has a pretty low melting temperature compared to copper, which is why you're able to melt it with a soldering iron. Whenever you operate the switch, you will get a small arc; if it's enough to damage the points over time, than it will melt the solder bead and the contacts with stick together, with power constantly applied to the window motor... not nice.
Yeah, new window switches aren't cheap from Mazda and are of no better quality either... I ended up making my own window switches using some carbon fibre plates, some rocker window switches from radio shack and a couple of 30A relays.
Sorry can't help much more.
Cheers,
- TT
Old Apr 18, 2007 | 11:39 PM
rx-7 2ndGen's Avatar
I just went to pick and pull and got some points off a mazda 626. I had to do some triming on them.
They work great...
Old Apr 18, 2007 | 11:46 PM
unW7WZ's Avatar
my pass side one pulled apart when i removed the door panel. i looked at the wiring diag in the fsm, and as i am not versed in reading wiring schematics i couldnt figure it out, so as a temp solution i ran a wire to the batt to close it. I am curious as well, so i could at least open and close it with the drivers side switch, but without the pass side switch in place it doesnt close the circuit. just curious on how this works as it may help me as well (knowing the wiring for the drivers side switches).
Apoc3D
Sep 5, 2015 10:24 AM
