tranny help
Old Sep 29, 2002 | 08:02 PM
Zalitore's Avatar
Question tranny help
ok i got the tranny outa my first car no prob
now i spent the rest of the night trying to put the thing in a diffrent car
both 85's one gsl and the original a gs now whats the trick ?. i cant get the drivetrain part that goes into the engine to line up properly i spent for ever holding the thing up and wiggling it around any ideas ? tips ? or tricks ? thanks ahead of time
Old Sep 29, 2002 | 08:31 PM
DriftinJim's Avatar
I've always had a friend tie a rope to the bolt hole on the top of the bell housing. They pull up on it to help take the weight off of me, then i get underneath, align the bottom part of the tranny and then pivot up the rear, aligning the rest, whilst the friend lifts up on command. Then, I tell them to get back in their cage or they get no supper.
BTW, 1st time i did a tranny job, took like 20 mins to get it in, 2nd time it honestly took about 15 seconds.
Old Sep 29, 2002 | 08:35 PM
Zalitore's Avatar
hm... sweet thanks for the idea
yeah its hard to aling it while benching the thing over top of you heh not to mention in the dark. but tommorow i will get it in easier now
Old Sep 29, 2002 | 10:08 PM
WackyRotary's Avatar
standard combustion
My technique is simple, no partner nessessary....if you have some strength and good built leg muscles from riding bicycle. Anyway, have the whole car off the ground with jackstands/ramps. Now get the two long tranny mount bolts and a 14mm socket wrench in hand. Get the tranny under the car and manuver it over you and hold it up with your legs and stomach, this is straight in line with engine ofcourse. Lift the bell housing up with your legs and arms with the rear of it and slide it on! You may get dirty if you haven't cleaned your tranny housing though.
Usually it goes on right like its magnetically attracted to the engine. Best of all, you have a tremendous viewing angle and can pretty much point and goes on. It helps to watch the upper bolt sticking out of the engine to match it up. VERY straight forward.
Till I learned this trick, I would be frustrated for hours!
Then ofcourse once its mated to engine, hold the rear up and put in 1 of the 14mm bolts and then the other, everything else is easy.
Old Sep 30, 2002 | 06:41 PM
Zalitore's Avatar
wow. i tried everything i donno how the hell you get it in
the gear shifter gets in the way or something else does
it just wont go in. anyway im just gonna toe it to a friggin shop. if i try anymore im gonna end up setting both cars on fire
Old Sep 30, 2002 | 07:12 PM
standard combustion
Don't burn it, sell it to me!
Old Sep 30, 2002 | 08:03 PM
CrazyJoe12a's Avatar
remove the shifter before trying to put it in. It's just 3 10mm bolts.
Jetlag
Sep 29, 2015 06:52 AM
