2 questions.. ....
Old Sep 28, 2002 | 09:39 PM
marshp's Avatar
Registered Rx7 Owner
2 questions.. ....
if you can help me with either of these i will love you long time
I want to get rid of that sooo annoying door buzer on my 83 rx7 gs, where is the fuse or something so i can take it out or do i have to cut a wire or what, i cant stand it cause if my doors are open and my stereo is on it always goes ding dong ding dong... etc.
when i set my ignition in the accessory position, like say im parked with my stereo on i dont want it so my lights are on, like my parking lights.. is there any way to change that?
Old Sep 28, 2002 | 09:42 PM
Directfreak's Avatar
I am a Jeeper Now.
Re: 2 questions.. ....
Close the door. Or remove the key from the ignition. - Just Kidding!!
?? Turn the lights off. One has nothing to do with the other.
Old Sep 29, 2002 | 01:18 AM
Manntis's Avatar
add to cart
Your park & dash lights shouldn't be on with your key in accessory position - they come on by turning the switch on the left stalk to the middle position or all the way to 'headlights up'. - they stay on as long as the switch is there, even if you pull your key from the ignition switch.
As to your door buzzer you could always disconnect the two switches in the door frames that tells the car the dor is ajar ("it's not a jar, you can't screw off the top" etc. etc.) but then you lose your dome light automatically coming on when the door is open.
Old Sep 29, 2002 | 02:40 AM
marshp's Avatar
well my lights stay on as long as its in accesory even if im sure the left stalk switch is set to all the way off, not the middle, and the lights stay on, i dont understand
Old Sep 29, 2002 | 03:56 AM
Manntis's Avatar
add to cart
then you have wires crossed in your steering column. Possibly a short circuit. Fix it ASAP as there's a potentially lethal fire hazard there.
Old Sep 29, 2002 | 10:04 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
I bet it has less to do with something factory wired wrong or malfunctioning than it has to do with someone wired something wrong somewhere. probally something aftermarket that was added such as a radio/guages?
Old Sep 29, 2002 | 10:11 AM
851stgen12a's Avatar
Off riding sportbikes!
Yea I agree with Mike, but would still check it out just in case. Better safe than sorry
Old Sep 29, 2002 | 01:41 PM
Manntis's Avatar
add to cart
Not neccessarily factory wired wrong, but probably a back yarder 'repairing' light wiring.
In my '83 some previous owner had 'repaired' the oil pressure gauge resulting in a seeping of oil above the steering column (it was the type that sends oil to the gauge to read the pressure) Had I ever had an ignition short prior to fixing this 'repair' I'd have become a human fireball.
Old Sep 29, 2002 | 04:14 PM
Defprun's Avatar
Punk Ass Bitch
You would no-longer be human if you were a fireball, you would be ash and some left over carbon.
Old Sep 29, 2002 | 05:35 PM
MIKE-P-28's Avatar
Thats quite a morbid way of describing Manntis' demise
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
93FD510
Oct 1, 2015 02:00 PM
