Sequential shifters for our cars!
Old Sep 26, 2002 | 10:46 PM
boostmotorsport's Avatar
Check this link out.
http://www.importfan.com/subcatmfgpr...8&1=447&2=1269
Is it just me or does this seem too good to be true?
Old Sep 26, 2002 | 10:53 PM
Felix Wankel's Avatar
Super Newbie
Its not clutchless though. Pretty damn good waste of 1500 bucks.
Old Sep 26, 2002 | 10:54 PM
It would still feel awesome(IMO), and shift faster
Old Sep 26, 2002 | 11:20 PM
Rotorific's Avatar
I dont know a damn thing
uh you would only use the clutch when you start 1st gear right i mean just like a regular seq trans?????
Old Sep 27, 2002 | 12:31 AM
Silkworm's Avatar
Has been.. hangin' around
No, that's just a shifter, you'd still need to use the clutch.
PaulC
Old Sep 27, 2002 | 12:38 AM
dr.jones63's Avatar
It's a Hammer
I want one of those paddle shifters that they put on the steering wheel of roadracing cars like the Subaru WRX
Old Sep 27, 2002 | 12:48 AM
thedguy's Avatar
They come as an option on any Ferrari now (the paddle shifter was Ferrari's design odly enough).
Old Sep 27, 2002 | 01:41 AM
NRA T2's Avatar
if it's worth 1500 bones to you to click instead of shift
Old Sep 27, 2002 | 06:47 AM
87GTR's Avatar
the problem with the ikeya shifter is they are made for RHD cars and the shifter is tilted to the right.
so if you got one for a LHD car it would be easy for passanger to shift for you. but he would have warn ya to use the clutch.
as far as I know they dont make then for the FC I have seen them in FD and the shifter sits almost as high as the top of steering wheel.
Old Sep 27, 2002 | 09:39 AM
FPrep2ndGenRX7's Avatar
Get the Guru Motorsports trans for fast shifting.
www.gurumotorsports.com
Old Sep 27, 2002 | 11:51 AM
jimmyv13's Avatar
Round&Round not Up&Down
That Guru dogbox is sweet, but $5K
Old Sep 28, 2002 | 01:30 AM
dr.jones63's Avatar
It's a Hammer
A friend of mine wired his dsm to disengage throttle when he steps on the clutch. The clutch is wired to the ecu (cuts boost when throttle is depressed) anyway so I know it can be done. Great mod for drag racing, just keep it floored.
Old Sep 28, 2002 | 01:31 AM
dr.jones63's Avatar
It's a Hammer
oops!!! cuts BOOST when clutch is depressed
Old Sep 28, 2002 | 09:47 PM
DrJones, thats friggin awesome, but how does the ecu cut boost? Are the WG's electronically controlled on those?
Old Sep 28, 2002 | 10:37 PM
Silkworm's Avatar
DSM's have an electronic connection to the throttle? I'd be very surprised at that..
PaulC
Old Sep 28, 2002 | 10:41 PM
dr.jones63's Avatar
It's a Hammer
The clutch has a connection to the ecu, like you have to depress the clutch to start, wont make boost when the clutch is depressed (opens wastgate) etc.. Someone on the DSM site wired a gizmo ( a relay to the tps I guess) that works off the clutch signal. Works excellent for drag racing, just keep it floored even when shifting.
Old Sep 28, 2002 | 10:44 PM
dr.jones63's Avatar
It's a Hammer
Just watch the boost gauge when you depress the clutch. Thats called automotive engineering
Old Sep 28, 2002 | 11:06 PM
peejay's Avatar
Old [Sch|F]ool
Why would it shift faster?
You can't shift any faster than the transmission (synchros) will let you. Anything that doesn't alter the synchros in some way, will have no effect on shift speed.
Old Sep 29, 2002 | 11:39 AM
dr.jones63's Avatar
It's a Hammer
Less chance for driver error. Max potetial of car.
Old Sep 29, 2002 | 11:50 AM
Super Newbie
Yeah instead of driver error, you have more chance of mechanical faliure instead from all the **** that the shifter has to use.
Old Sep 29, 2002 | 11:53 AM
OC_'s Avatar
OC_
I'm bastardizing my car!
sounds like the guru could be a partial crash box.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
NoMorePoison
11
Aug 18, 2015 11:18 AM
