2nd Turbo Kicking Question! :)
Old Sep 25, 2002 | 12:43 AM
DashKits.net's Avatar
Question 2nd Turbo Kicking Question! :)
i feel the 2nd turbo in
1st gear all the time.
(AUTOMATIC)
but in 2nd gear i never feel it kick in at WOT-
it's just smooth pulling the entire way to redline.
is this normal?
i dont have a boost gauge yet,
but i was wondering if i should be able to feel the
2nd turbo kick in 2nd gear and 3rd gear.
thanks!
Old Sep 25, 2002 | 06:11 PM
ttt
thanks
Old Sep 25, 2002 | 06:43 PM
jkprelude's Avatar
You should be able to feel the switchover from the first to the second turbo. So...I guess the answer is yes. You should feel a little something because the power dies off for a split secong while they switch.
Old Sep 25, 2002 | 06:52 PM
thats what i think too
in first gear, its obvious when it comes on...
but in second gear, its
smooth the entire RPM range...
i need a boost gauge to see whats up eh?
thanks
Old Sep 25, 2002 | 07:21 PM
Bro, you will need a boost guage for your FD no matter what. It sure gives me peace of advice that im not having any boost spikes and setting up a time bomb for my engine.
Nathan
Old Sep 26, 2002 | 02:37 AM
Batmobile's Avatar
Yes....boost should kick in in 2nd gear....and througout the rest of the gears....not to be a smart ***...but that's the whole point of Sequential-Turbos...get a boost gauge...primary boost should shoot 10psi and then changing gears it should drop to 8 psi....then climb back up to 10psi...
Once you get you boost gauge...if the boost pattern isn't 10-8-10...then you may have boost problems.
I hope that helps bud.
Queppa
Nov 18, 2024 03:47 AM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
