Alternators
Old Sep 24, 2002 | 07:36 PM
85RX7GS's Avatar
Alternators
Does anyone know the ampere ratings on the 2nd gen alternators? Are the 86-87 and 88-90 grouped similarly? Thanks.
Old Sep 24, 2002 | 07:38 PM
S2-13BT's Avatar
75 amps, I'm pretty sure. I think both series are the same.
Old Sep 24, 2002 | 07:41 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
I think my 88 vert is 70 or 75 I forget. The cosmo one I got is a 90 amp
Old Sep 25, 2002 | 10:53 PM
mar3's Avatar
Administrator
The '89-'91 TII alternators are grouped separately by ampere output which is 80 amps peak. It is also a relatively easy mod...here's the rest of the story....
The Ultimate Alternator thread with pictures, no less...
Old Sep 25, 2002 | 11:50 PM
gamble302's Avatar
roadkill hats rock
do the 2nd gen dual alt belt kits work for us too? too lazy to search for now
gamble
Old Sep 26, 2002 | 12:41 AM
mar3's Avatar
Administrator
Where's DF and his graphics when you need him?? It's been brought up before and I believe the answer was "yes", but I'm too sleepy to confirm that belief right now....yawn....anybody know the definitive answer? ie., who has done it themselves...none of this "I have a friend" stuff...
Old Sep 26, 2002 | 12:38 PM
82transam's Avatar
Never Follow
86-88 are 70 amps, while 89-91 have a different connector and 80 amp output
Old Sep 26, 2002 | 02:12 PM
Jeff20B's Avatar
Lapping = Fapping
Heh, I've got a 55 amp 2nd gen alt. It works fine where an old stocker rated at 50 amps used to be. I don't even need to change my fuse.
Old Sep 26, 2002 | 02:18 PM
Project84's Avatar
Open up! Search Warrant!
'86-'88 = 70 amp.
'89-'91 = 80 amp.
'93+ = 100 amp.
These are stock numbers from the manufacturer
Old Sep 26, 2002 | 07:35 PM
85RX7GS's Avatar
Originally posted by Project84
'86-'88 = 70 amp.
'89-'91 = 80 amp.
'93+ = 100 amp.
Thanks! That's exactly what I was looking for!
Old Sep 26, 2002 | 07:37 PM
85RX7GS's Avatar
Thanks!
Old Sep 26, 2002 | 09:21 PM
82transam's Avatar
Never Follow
Originally posted by 85RX7GS
Thanks!
no prob, you should swap them, it takes all of a half hour
Old Sep 26, 2002 | 09:37 PM
82transam's Avatar
Never Follow
FD's use a serpentine belt system so making that work on a FB would be tough, the 80 amp 89-91 alt is more than enough power.
Old Sep 26, 2002 | 10:16 PM
Directfreak's Avatar
I am a Jeeper Now.
Originally posted by 13K ReDLiNE
so will a 93+ alt fit??? I have a lot of power drain (hiperf fuel punp, elec water pump, big stereo, electric fan, 3 coils)
On my Cosmo alternator (serpentine belt) I bought a Racing Beat dual pulley and drilled the hole slightly larger to fit the larger diameter spline.
While I was at it, I had a smaller diameter dual pulley drilled and prepped for the same alternator, because it is not underdriven like the Racing Beat one.
Old Sep 26, 2002 | 10:19 PM
82transam's Avatar
Never Follow
Yea, that would do it. But then isn't there any issue with the fuseable links? The main one is rated at 80 amps, wouldn't putting a alternator bigger than that blow it constantly? Even if you swap to a FC fuseblock the main fuse is still 80 amps. Just a thought
Old Sep 26, 2002 | 10:24 PM
I am a Jeeper Now.
I am switching to the FC fuseblock, & moved the battery to the passenger bin. I also got a "painless wiring" additional fuseblock to control all my accesories, and additional gauges, etc.
The Cosmo amp is rated at 90 amps, so considering the additional draw and upgraded (new) wiring, I should be fine.
Old Sep 26, 2002 | 10:27 PM
82transam's Avatar
Never Follow
Yea, sounds like your fine. I got a fc fuseblock a few weeks ago, but haven't taken the time to put it in yet. the fact that i'm kinda confused on how it is wired doens't help. oh well, thats a thread for another day.
Captain Hook
13
Oct 4, 2015 06:35 PM
Robrods64
Oct 2, 2015 07:56 PM
WANKfactor
Sep 29, 2015 01:14 PM
