Quick-fuel pump jumper!
Old Sep 23, 2002 | 04:02 PM
Ryde _Or_Die's Avatar
Alright I need to jumper my fuel so its runs. I know its supposed to be a harness by the p/s strut tower bar but I can't find it. The only one I can find has 4 wires going into the back of it and its like attached to the fender well or something. If someone can give me some quick directions exactly where it is, please do. Or a pic would work even better. Thanks.
Old Sep 23, 2002 | 04:07 PM
jacobcartmill's Avatar
just dont care.
mine was barely sticking out of the harness right next to the shock tower, underneath the TID. it didnt do anything to help me starting my car. maybe i have the wrong plug?
Old Sep 23, 2002 | 04:09 PM
I dunno man. I can't find it. Anyone with a pic?
Old Sep 23, 2002 | 04:10 PM
just dont care.
you looked under the AFM right?
Old Sep 23, 2002 | 04:11 PM
Ya as much as I can see. I will go look some more, brb.
Old Sep 23, 2002 | 04:13 PM
J-Rat's Avatar
Alcohol Fueled!
I can get yo ua pic if you need...
J-Rat's Avatar
Alcohol Fueled!
I believe the plug is Yellow
Old Sep 23, 2002 | 04:20 PM
just dont care.
yes lets please see a pic, i need to make sure i jumpered the right connector.
Old Sep 23, 2002 | 04:27 PM
J-Rat's Avatar
Alcohol Fueled!
Here
Old Sep 23, 2002 | 04:30 PM
just dont care.
so it is that little yellow one... what is that green one that you have those wires coming out of.
Alright I found it and got it jumpered. Turns out my PD wasn't leaking, it was a hose going to the pri. fuel rail. Time to go buy some hose. Thanks guys.
Old Sep 23, 2002 | 04:31 PM
just dont care.
you had a fuel leak?
J-Rat's Avatar
Alcohol Fueled!
Thats the TPS sensor, the wires coming out are the LEDs I have hooked up to it... I am monitoring my TPS right now, to see if its acting wierd...
Old Sep 23, 2002 | 04:32 PM
just dont care.
what do you mean by PD
Old Sep 23, 2002 | 04:35 PM
J-Rat's Avatar
Alcohol Fueled!
Pulsation Damper...Common failure item on these year/model cars.
Old Sep 23, 2002 | 04:46 PM
DaleClark's Avatar
RX-7 Bad Ass
BTW, that green plug is the TPS check connector for NA's - the TurboII's TPS check connector is over by the oil filter neck.
Glad you found it, Ryde - it's a good feeling when you see where the leak is coming from! If the stock hose clamps on the hose are in good shape, use them - spring type clamps give constant pressure on the hose as it expands and contracts with heat. Worm drive clamps don't. But, if the stock clamps are shot, worm drive clamps WILL work. They're just not optimal.
Dale
Old Sep 23, 2002 | 06:10 PM
Yep, thats the reason my car has been sitting. Luckily I found it before anything caught on fire. It was the fuel hose going to the primary fuel rail. It was leaking pretty badly. Damn I prolly was getting better mileage than I thought.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
FC_DREAMS
Sep 9, 2015 06:24 PM
BLK 93
11
Sep 9, 2015 10:56 AM
