60-1 Turbo with Airpump???
Old Sep 23, 2002 | 12:44 PM
Fatty_FC3S's Avatar
Does anyone know if a 60-1 turbo will work/fit while the stock airpump is still on the car (89 T2)? I have to smog my car and wanted to know if i upgrade to a full 60-1 can i put the airpump on and smog the car, then take it back off for nomal driving? Do i have to remove the turbo every im i smog? Just wanted to know since im not sure how much room that 60-1 takes up in the engine bay. Thanks
Graham
Old Sep 23, 2002 | 12:51 PM
PraxRX7's Avatar
wondering...
I wonder if you could just remove the air-pump and install a 12V system electrical air compressor in its place...
Old Sep 23, 2002 | 01:02 PM
OC_'s Avatar
OC_
I'm bastardizing my car!
Re: wondering...
thats what im trying to do right now. I got a small air compresser off of ebay thats normaly used for powring air horns. Some one else here is doing the same thing.
Old Sep 23, 2002 | 01:12 PM
DaleClark's Avatar
RX-7 Bad Ass
The 60-1 will work with the stock airpump, but the exhaust manifold would have to be custom. Most manifolds move the turbo up and forward, right into the air pump.
You would probably need a higher volume air pump to do the job - Brian Cain used a Corvette electric air pump and was able to pass smog.
Remember, going with a large turbo and the like it's REALLY easy to get in a situation where you wouldn't pass emissions, especially if they do a visual inspection. Unless you're very familiar with emissions and fuel injection, you might want to keep your mods more reasonable.
Dale
Old Sep 23, 2002 | 06:46 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
YEAH. What Dale said.
Oh... BDC mounted the 'vette airpump approximately where the "sub zero assist" was located.
Old Sep 23, 2002 | 06:49 PM
Scott 89t2's Avatar
SOLD THE RX-7!
do you need to pass a visual? or just tail pipe?
Old Sep 23, 2002 | 09:06 PM
bkapold@aol.com's Avatar
I'd have to agree with the others... I have a T60-1 on an HKS manifold and the turbo sits about where the air pump use to sit....
Old Sep 24, 2002 | 02:00 PM
Fatty_FC3S's Avatar
To my knowledge i dont have to worry about visual test. I did that 2 years ago and everything was ok. I have the tools to change turbos and stuff, but i wanted to sell my turbonetics stock upgrade to help pay for the new 60-1. The corvette airpump sounds like a good idea if i dont have to deal with visual. Could also get a junk stock turbo and put it on just for smog, doesnt have to be all that good of a turbo. I figured the 60-1 went where the smog pump goes, but wasnt sure. thanks for your help
Graham
Old Sep 24, 2002 | 03:48 PM
Cheers!'s Avatar
Former Rx7 *****
just a side note... making everything electrical isn't as easy as it may seem.... the FC electrical isn't the most robust in teh world
Old Sep 24, 2002 | 03:56 PM
Your talking about the oem ecu stuff? Get rid of that stuff, it will fail you eventually
Old Sep 25, 2002 | 12:37 PM
Fatty_FC3S's Avatar
Im not too concerned about running new feeds off the electrical system. I dont have the stock ecu anymore (WOLF 3D instead) and i have a big bad 190amp alternator that will have no problems handling the corvette air pump. Thanks for the thoughts though, good things to think about
Graham
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
