weight of precat and catback
Old Sep 23, 2002 | 12:37 PM
ttb's Avatar
ttb
No Cup Holder Racing
anybody know the weight of the stock pre-cat and catback. wondering how much if any wieght i have reduced with a downpipe and aftermarket cb.
thanks
Old Sep 23, 2002 | 01:03 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Not sure of the EXACT numbers... But the Precat is like 40 some odd lbs... The average DP is probably 8-12lbs. The stock catback is WAY heavy... Again don't know the numbers, but most ALL aftermarket catbacks are less than half I'd guess. Replacing the CAT with a high-flo can shed quite a bit too. My hi-flo is easily 1/3 the weight of the stock main cat.
Old Sep 23, 2002 | 01:11 PM
Mr. Belvi's Avatar
Stock pre-cat: ~22.6lbs
Stock cat-back: ~34lbs
Old Sep 23, 2002 | 02:13 PM
Rated R1's Avatar
Oji San
Where did you get those numbers from Belvi? I have a gutted precat and it feels like it weighs more than 22 lbs.
Old Sep 23, 2002 | 02:15 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Really? I thought they were significantly more than that... At least they feel like it!!! Thanks for the numbers.
Old Sep 23, 2002 | 03:56 PM
94RXMAGEE's Avatar
I just weighed mine:
Stock precat: 22lbs
Stock main cat: 32lbs
Not sure on the catback though.
Old Sep 23, 2002 | 04:44 PM
maxcooper's Avatar
WWFSMD
I have weighed all the stock exhaust parts personally. Here's what I found:
pre-cat: 23 lbs
main cat: 30 lbs
cat-back: 34 lbs
Replacements I have weighed are:
RP SS downpipe: 8 lbs
N-Tech HF cat: 13 lbs
RB dual tip black CB: 31 lbs
GReddy PE CB: 28 lbs
Weight savings: 35-38 lbs, and you can get even lighter parts. Of course, lighter is generally louder, so you might want to get something other than the lightest parts you can find for the exhaust if noise is a concern.
-Max
Old Sep 23, 2002 | 10:10 PM
Mr. Belvi's Avatar
Whelp, looks like I was correct.
Old Sep 24, 2002 | 12:09 AM
Plenty of time
Max,
You kinda have a lot of time on your hands dontcha? j/k Thanks for the actual data once again.
Old Sep 24, 2002 | 01:03 AM
maxcooper's Avatar
WWFSMD
I just like to know how much the stuff weighs. Never mind that I could probably drop 50 lbs off my fat *** for some real weight reduction. Replacing heavy parts on the car is just so much easier.
My latest weighing: the big RZ rear rotors, Wilwood NDL calipers, brake pads, lines, and caliper brackets weigh about 36 lbs total. I will weigh the stock parts they replace if I find myself with a bunch of extra time.
-Max
Old Sep 24, 2002 | 01:56 AM
93blackrx's Avatar
Seen the new JIC Titanium Exhaust yet? Is it really worth all that money?
matt
Old Sep 24, 2002 | 02:22 AM
maxcooper's Avatar
WWFSMD
Generally, light = loud. I am trying to make my car quieter, so I am no longer chasing weight out of the exhaust system. Stanless is generally lighter than mild steel because it can be thinner. I would expect titanium to be even lighter than SS. There is a lot of weight to drop in the exhaust system.
-Max
cto_2
19
May 8, 2018 08:15 AM
MILOS7
May 9, 2016 06:39 AM
