Short shifter... ??? How do they do it?
Old Sep 20, 2002 | 09:43 PM
79+80_rx-7's Avatar
I mean... You COULD cut the shfiter lever/rod down.... but WHY? you loose leverage.. harder to shift....
So I was thinking how they make them... so I thought, did they move the extend the rod below the pivot point cause longer stroke?
Or did they move the piviot point up?? Or what??
Please help me with this... i am super curious..
Peace
Old Sep 20, 2002 | 09:59 PM
S2-13BT's Avatar
They move the pivot point up. You mount it using a spacer on top of the stock mounting point. The rod is shorter too, so it looks basically the same but the throw is shorter.
This is the www.horsepowerinabox.com version
Old Sep 21, 2002 | 12:44 AM
gamble302's Avatar
roadkill hats rock
yessir thats how it works. ive got the mazdatrix one and it works great. its 192 bucks though! lucky for me it came with the car when i bought it
Old Sep 23, 2002 | 08:16 PM
rxdoom's Avatar
There are kits around that you can use. or you could just chop a bit off the top of the shift.
Your best bet is getting a kit.
Old Sep 23, 2002 | 09:12 PM
onepointone's Avatar
i say what i want
has anyone done this themselves? i was going to do it, but i never got around to it, i looked up a couple ways to do it.. but they were all different and i figured i would **** something up.. anyone have an pictures on how this needs to be done, im a good welder, so thast not a problem
Old Sep 23, 2002 | 11:00 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
I did'nt weld ****! I simply chopped off what I did'nt want, put it in a vice, and threaded it.
I had a lathe, and made an aluminum shft **** with a hole in the bottom. I put really coarse threads on the end of the lever. (That lathe did'nt thread, and I only had one huge die to thread with.)
The **** basically just threaded itself on there because aluminum is so soft.
To do it better, you would buy the **** you want (or stock) and properly thread the lever for it to fit. You might first angle the tip of the lever, if you like. (The threads would get messed up if you did it later.)
This makes for a very hearty, "notchy", purposeful shift that takes more effort. If you get pumped while driving and tend to be hard on the lever, you'll like the feel of this mod.
If you want a shifter that seems to slip into gear effortlessly and smoothly, buy the other.
You might do a search. You will probably find about three or four other ways it's been done.
Old Sep 23, 2002 | 11:08 PM
Directfreak's Avatar
I am a Jeeper Now.
I drove a modded '85 GS with this mod. It had the Mazdatrix one in it.
I didn't like it. Literally 2 inches between throws. EXTREMELY notchy. Felt like a nintendo joystick.
I would hate to drag race with it, I'd probably get 1/3/5 confused, as well as the 2/4 gears.
Old Sep 24, 2002 | 03:28 AM
gonzz's Avatar
I remember someone was cutting and welding them for 20.00??
Old Sep 24, 2002 | 09:43 PM
i say what i want
my friend has a low 14 sec crx and his throw is less that 1.5". he cut and welded it himself in 3 different places i believe. i wasnt to sure about it hte first time i drove it, because its so much power, and its really easy to miss second and third. but with a little practice i got used to it, and ended up liking it. i dont want it that short in my car, but i think 2-2.5 would be nice. definatly dont want to pay the money for a professionally made one though.. ill probably get one from a junk yard to mess around with so incase i **** it up, im not out of luck
Old Sep 25, 2002 | 02:29 AM
gonzz's Avatar
Ok, someone step-up and hook our shifters up.. and make some extra $$ doing it.. I got 2 to get done..
Old Sep 26, 2002 | 07:28 PM
Pistonfister's Avatar
I cut and welded mine about a year ago. I think I took about an inch off. I wasnt to impressed. I thought it looked kind of cool but now it feels notchy and not much improvement in throw. For my next one I will buy one that has been profesionaly made with the piviot piont raised.
Old Sep 26, 2002 | 07:35 PM
gonzz
Sre you just looking for someone to cut and weld your shifter shorter? Or are your looking to have someone change the piviot point? I can cut and weld them. Mine has held up just fine but like I said I wasnt to impressed. The only was to do it change the piviot piont in my opion. I have an extra shifter in my garage maybe I will give this a shot what could it hurt? If you raise the piviot a 1/4 inch then you would just need to fabricate a spacer that is a 1/4 larger I would asume.
Old Sep 26, 2002 | 08:55 PM
i say what i want
well, if you do end up doing it, could you PLEASE take pictures? im VERY interested in doing this
Old Sep 26, 2002 | 10:31 PM
82transam's Avatar
Never Follow
my friend just got a B&M short shifter installed in his ZX2 yesterday, its 1" between 1st and 2nd, its totally nuts. I don't know how you could shift something like that. I like my 83's shifter the way it is.
Old Sep 26, 2002 | 10:51 PM
Felix Wankel's Avatar
Super Newbie
Old Sep 27, 2002 | 01:23 AM
gonzz's Avatar
Pistonfister: yah take some pics.. I have a 80 and they don't make a short shifter for it.. can you make me one?
Old Sep 27, 2002 | 09:11 AM
damon's Avatar
I dont know guys, I like to have the shifter as close to my hand on the steering wheel as possible for my kind of country backroad (racing) driving style. I have about 12-15 hairpin turns on my way to and from work and you all know I take advantage of the rear drive slide manuvers. This is just my opinion on the subject, and Im a post ***** (lol).
peace
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Sethix
Nov 3, 2017 11:48 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
