a question no one can answer.
Old Sep 17, 2002 | 07:35 PM
OC_'s Avatar
OC_
I'm bastardizing my car!
Im sure no one will know this... But i need to know!
heres the Q:
How long is the throw on the actuator that operates the 5th and 6th ports on a 13b na?
Old Sep 17, 2002 | 07:47 PM
1FastT2's Avatar
Do you need to know an exact measurement or an approx, dimension?
Old Sep 17, 2002 | 07:52 PM
Aaron Cake's Avatar
Engine, Not Motor
Exactly 1.2 CM for an '86-'88...Come on, give me a hard one...
Old Sep 17, 2002 | 07:54 PM
Icemark's Avatar
ah Aaron you beat me too it
Old Sep 17, 2002 | 08:59 PM
OC_'s Avatar
OC_
hmm... how long is it on a 90' ... it seems a lot longer then 1.2 cm. It looks to be over an inch (2.54cm).
My plan is to remove the actuators completely and replace them with electric solenoids. This is so i can mess around with things that are going to effect the operation of the actuators. Yes, i know thers ways to use the air pump and all, but i could be tampering with that too.
Old Sep 17, 2002 | 09:07 PM
Aaron Cake's Avatar
Engine, Not Motor
Solenoids will not hold up to the exhaust heat. It's been tried before. But if you are going to do it, don't worry about the throw too much. Just get a solenoid good for 3 CM, and use a spring to take up the slack. Much less stress on the solenoid if it's done that way. Remember: the '90 atuators push up, not pull in to actuate the ports.
Old Sep 17, 2002 | 09:35 PM
Icemark's Avatar
What kind of electric actuator are you thinking??? Most electric actuators like tape head or door lock motors can't stand a heavy on period, like driving would entail.
The other draw back for electric actuators is the life cycle. A common OEM door lock actuator has a about a 15000 cycle life. That’s about 4 times a day for 10 years... yet your gonna hit 3800 RPM how many times a day??? Say you drive 10 miles and back in med traffic, that would be easy 30 or 40 times.
That’s about 500 miles before the actuator dies.
Old Sep 17, 2002 | 10:15 PM
OC_'s Avatar
OC_
http://www.electromechanicsonline.co...2EC%2E%2C+Push
I wasent thinking door latch solenoid ever. take a look at these.
you can get them with a continuous duty cycle.
Old Sep 18, 2002 | 12:46 AM
Sammymatik's Avatar
Damn, that is sick. The man really, really knows his 7 don't he?
Old Sep 18, 2002 | 12:56 AM
Scott 89t2's Avatar
SOLD THE RX-7!
Exactly 1.2 CM,
only 1.2cm? dam Aaron... now I know why you needed that turbo
ah IC... that lengh wasn't when hard?
Old Sep 18, 2002 | 01:07 AM
Icemark's Avatar
Intresting design, but requires massive heat sinks, for example the 25mm push was requiring a 2"x2"x3.2mm heat sink, so your gonna need some way too sheild and cool them in the engine compartment. It appears they are rating them at 70F or slightly less.
_Tones_
May 25, 2021 05:37 AM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
Nosferatu
Sep 5, 2015 02:13 PM
