dumb questions i'm sure, but i'm new with rx7
Old Sep 17, 2002 | 01:43 PM
Cubfan's Avatar
Hello
i have a couple basic questions, My car is stock right now.
which of the 2 coils is the leading one.
also which of the spark plugs are the leading ones on the block.
and should i use different plugs for the leading and the trailng?
this t1 t2 isnt making sense to me, or am i just making more out of it than i should?
thank you
Old Sep 17, 2002 | 01:49 PM
zyounker's Avatar
root
T1 is trailing 1 and t2 is trailing 2.. The other to should be marked L1 & L2 for leading 1 and leading 2....
Go with NGK plugs and leading has different plugs then the trailing.
-Zach
Old Sep 17, 2002 | 02:05 PM
Cubfan's Avatar
Many thanks Zach
i dont want to sound dumb but my 10 year old son pulled the wires off my disturbutor cap last night
and i dont know what goes where.
which coil on the fender is the leading coil?
and which plugs on the block are the leading. are they the top plugs?
Old Sep 17, 2002 | 02:08 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
I think? from memory the coil closest the front of the car is the trailing coil. The trailing coil will have a blue boot on its positive, and the - neagtive tach signal will be a blue single pin molex
Old Sep 17, 2002 | 02:10 PM
MIKE-P-28's Avatar
top plugs are Trailing theres a T on the block
bottom plugs are Leading theres a L on the block
The set closest to the front is rotor 1, thus T1 on top, L1 on the bottom, back rotor is T2 on top, L2 on the bottom
smikels
Rtek Forum
May 12, 2016 12:34 AM
c0rpse
Aug 25, 2015 11:50 PM
OrangeMax
Aug 22, 2015 12:05 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
