What's the best way to stretch hose ends?
Old Sep 15, 2002 | 05:21 PM
Question What's the best way to stretch hose ends?
So I'm in the process of replacing hoses, and some of the hose is 3.5 mm on one end, and something like 6-8 mm on the other end. Is there some prefered technique to get the hose to stretch? I was thinking of using a hair dryer or some other heat source and a large phillips tip screwdriver to stretch the ends.
Thanks!
Old Sep 15, 2002 | 07:26 PM
Jeff20B's Avatar
Lapping = Fapping
Add a tiny amount of oil to the nipple and force it on. Just enough to lube it and not greatly affect the rubber in a bad way. I've also used a screwdriver to sort of hone out a hose before too. It worked. Good luck.
Old Sep 15, 2002 | 08:04 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Should have seen me shoving that 3" onto my IC in/outs, that was a massive apin in the ***!! My wrist hurt for a week after that.
Old Sep 16, 2002 | 02:38 AM
nimrodTT's Avatar
all aboard!
Try fitting a pair of needle nose pliers in the end of the hose then opening the pliers to stretch the hose around the nipple.
24seven_dada
20
Nov 10, 2018 12:03 PM
ZacMan
Sep 19, 2015 09:20 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
BLK 93
11
Sep 9, 2015 10:56 AM
Frox
Sep 8, 2015 08:36 AM
