MSD 6a, Is it worth the money?
Old Sep 14, 2002 | 10:30 PM
JIMMY54's Avatar
GSL-SE PRO
I've tried searching but i couldn't really find any good info about this. Does it really give any noticeable increases in power? Is it a mod that is worth the money?
Old Sep 15, 2002 | 02:05 AM
Jeff20B's Avatar
Lapping = Fapping
Some say yes, some say no.
Old Sep 15, 2002 | 05:18 AM
Project84's Avatar
Open up! Search Warrant!
Its supposed to be a more reliable spark. I ordered the free catolog and checked out there web site.
This is from the brochure they sent me:
Below 3,000 RPMs the MSD's produce a series of sparks that lasts for 20 degrees of crankshaft rotation. This powerful series of sparks ensures combustion of the fuel mixture resulting in quick starts, smooth idle, and great throttle response. At higher RPM, the capacitive discharge circuits deliver full power sparks to produce great power throughout the entire RPM range of your engine.
Most people that have posted in the 2nd Gen section have been happy with the results, although a better ignition system doesn't "make" more power in the same terms as adding more air and fuel, rather it burns the air and fuel more efficiently, which in turns give better throttle response which feels more powerful.
Old Sep 15, 2002 | 09:41 AM
David88vert's Avatar
r71's daddy
I have it on my GSL-SE in direct fire mode. I was not impressed. Peejay loves his setup however.
Old Sep 15, 2002 | 10:24 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
depends on a lot of things...Personally out of the box type of thing it sounds ok. And its not really that expensive, its only expenisve if it dont impress you.
Old Sep 15, 2002 | 10:48 AM
I dont have one, i'm saving up for a 6al with rev limiter, but i would recommend it. You can score a 6al for under $200 bucks. Even if it doesn't improve horsepower that much it WILL improve fuel economy and you'll have a nice rev limiter. I know people who have them on a piston engine and they love it. Go for it!
Old Sep 15, 2002 | 11:01 AM
MIKE-P-28's Avatar
yeah $200 isnt expensive for a performance mod, I think even www.jegs.com and www.summitracing.com have money back gurantees
Old Sep 15, 2002 | 11:23 AM
JIMMY54's Avatar
GSL-SE PRO
Has anyone had any experience with the
Mallory Hyfire VI-A CDI ignition?
Old Sep 15, 2002 | 01:50 PM
Project84's Avatar
I've heard of it, and from what I understand, its pretty much the same as the MSD. CDI is Capacitive Discharge Ignition, and the differences bewtween the Mallory and the MSD is about the same as the differences between an 84 Camaro and a 84 Firebird, from what I read. I went to www.fc3s.org which is a site for 2nd Gen cars, and they did a write-up on installing a Crane Cam HI-6 ignition. They say that the MSD system uses analog circuits, where as the Crane is digital. If you want to read their write up, go to the site above, and on the left click on How-To's, and in the menu that drops down, click on electrical, and select Crane HI-6.
Old Sep 15, 2002 | 02:32 PM
peejay's Avatar
Old [Sch|F]ool
YES!!!!!
WyomingTII
May 31, 2018 09:00 AM
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
