bad wheel bearings -sounds like what?
Old Sep 11, 2002 | 12:45 AM
ncmn's Avatar
greetings,
i've been doing searches but cannot figure out what shot rear wheel bearings would soung like. at present i have this oscillating sound coming from my rear -sounds like a wobble (or going over those speed bump things on highway shoulders). it get louder/faster when i speed up and the opposite when i slow down. i thought differential but it seems that would sound like grinding/rattling. is it possible it's an alignment thing as the car does pull to the left big time. i've got an 84 gs if this is relevant. should i investigate anything else?
much appreciation,
norman ng
Old Sep 11, 2002 | 12:52 AM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
Sounded like a train for me.... chugga chugga chugga chugga chugga.... slow frequency at lower speeds, higher frequency at faster speeds. A rather low pitched sound; got progressively louder and louder over time.
Differential can sound the same, so I hear. The usual procedure is to replace both rear bearings (cheap if you do it yourself and use aftermarket parts, mazda parts are double the price) and see. If the sound is still audible, then you worry about rear end.
For me the rear bearings took care of it.
Old Sep 11, 2002 | 01:03 AM
peejay's Avatar
Old [Sch|F]ool
That's pretty much what the axle bearings sound like when they go. One hell of a racket, too, makes you think you're going to watch your wheel and axle pass you in the next lane
You could tell which one was bad by jacking up the car and spinning each rear wheel individually. Impossible if you have an LSD but you should be able to tell which side's making the noise, plus if it's bad enough you can feel the grumbling.
I waited until mine got so loud that it drowned out the exhaust, then I changed it. PITA even with the proper tools.
Old Sep 11, 2002 | 01:41 AM
Keaponlaffen's Avatar
Sounds like wheel bearings to me.... speaking of which, I should really do that in my car.... I can't tell what my car sounds like, 'cause all I can hear is the wheel bearings
Jeff
Old Sep 11, 2002 | 12:26 PM
brownmound's Avatar
Anytime baby!
Mine sounded kinda like a helicopter....a rythmic "waaah-waaah, waah-waaah, waah-waah, wah-wah" as you moved faster. pretty loud and not so good to lose, though I let mine for a while though they were toast when finally replaced. I had my mechanic do it as he has the tools and the know-how.
Of course the mound was once in a flood, so maybe that had something to do with bad bearings. ya think?
Right on.
Old Sep 12, 2002 | 11:57 PM
ncmn's Avatar
thanks everyone. going to have them checked monday and estimate for repair -dealership but one i actually trust. however...with only basic tools, driveway garage and my own sweat, how frustrating/scary a job is it to do yourself (considering it's my first time ever and i only have the manuals for experience)?
regards,
norman ng
Old Sep 13, 2002 | 09:04 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
On my 80, I swear it sounded like I had gravel floating around back there, it was LOUD!
Old Sep 13, 2002 | 12:09 PM
rx7passion's Avatar
the rears can be a bitch, good tip is to put the bearings and sleeves in the freezer overnight to help shrink them.
funny story my neighbor once wanted me to check out his chevy van cause it sounded really bad and didnt steer good at all, i suggested to check the wheel bearings. pull off the passenger front wheel and and brake assembly and hmm theres a wheel bearing but no bearings, the whole thing exploded and it was just jagged metal grinding against metal. never seen anything so funny
Old Sep 13, 2002 | 03:11 PM
peejay's Avatar
Old [Sch|F]ool
basic tools = not possible for the rear axle bearings.
You NEED a hydraulic press to put the new bearing and retainer sleeve on. It takes a minimum of 6 tons of force to put the retainer on. My shop's 12 ton press was flexing!
Old Sep 13, 2002 | 03:52 PM
ASEmaster's Avatar
I wouldn't say it's not possible w/ basic tools. You can take care of everything yourself EXCEPT for when it comes to pressing off old bearings and pressing on new ones. Once you get the axles out you take them to any competent machine shop and they can do their thing with a press.
I suggest replacing the axle seals while you're at it.
Old Sep 13, 2002 | 04:10 PM
peejay's Avatar
Old [Sch|F]ool
That's not really doing it yourself if you take the axles to a shop
The axle seals are supposed to be very tricky to get installed properly. If they're not square with the housing, they can leak. I just remove the axle very carefully so that I don't damage the seal, and reinstall carefully. No problems.
Old Sep 14, 2002 | 12:00 AM
ncmn's Avatar
the shop it is.
norman ng
Old Sep 14, 2002 | 07:07 AM
Nah, you can do it yourself with basic tools. I did. It takes a *long* time, but the bearing/collar will go on with a big hammer hitting a big wrench over top of them. When I got sick of waiting, I held the wrench while my friend slammed a heavy *** old flywheel/clutch assembly (lol) down the axle. That hurt my wrist like ****, but it worked much quicker.
The easier way to do it, is to get a length of pipe in the appropriate diameter, put it over the axle, and hit that with the hammer. You'd be set then.
Anyways, I'm just saying that it's a completely do-able job in the driveway, with basic tools and a little improvising. It just isn't always a barrel of laughs (or maybe it is, depending on who's holding the wrench lol). For my money, I'd rather save the $$ and do it myself, but I'm a brokeass student, so....
The only special tool you'll need is an axle-puller, but you can borrow that from most parts stores that loan out tools.
Old Sep 14, 2002 | 07:36 AM
ASEmaster's Avatar
Everyone I've talked to that's done this said the axles came out pretty hard, but I just gave mine a little tug and they pulled right out. Hope that doesn't mean I've got a problem !
I used an appropriately sized wood block to drive my new seals in. They make seal installation drivers and in retrospect, that's probably the way to go next time. Peejay is right, it's VERY important that they end up straight when you're done (ask me how I know!).
Old Sep 14, 2002 | 07:47 AM
One more tip...
When you're bolting up the puller, make sure to tighten those lug bolts down nice and tight... otherwise you'll be re-tapping your axle threads.
Go ahead, ask me how I know
fidelity101
13
Aug 31, 2015 07:47 PM
RaY358
Aug 19, 2015 11:44 PM
Marty RE
Aug 17, 2015 09:36 AM
