re-wiring pump, screws wont come out.
Old Sep 8, 2002 | 11:17 PM
PraxRX7's Avatar
My check engine light just came on for a split second for the first time in 2 years.
I know it is the fuel, I want to re-wire the fuel pump, but I cannot get the screws off to pull it out of the tank. They are heavily corroded. What are my options for getting them out? (the cover on the tank, not the first cover)
Old Sep 9, 2002 | 12:23 AM
Scott 89t2's Avatar
SOLD THE RX-7!
I'm not sure why you think the check engine light has anything to do with the fuel... but anways...
you don't need to pull it out. I just ran my wires and connected them outside in the trunk. it won't make any diff going all the way. and I don't think you could get a bigger wire though down to the pump anways.
however when it comes time to replace it... that'll be fun. My friend had to drill his out. mine came out fine
Old Sep 9, 2002 | 12:24 AM
Scott 89t2's Avatar
SOLD THE RX-7!
just don't use a torch to heat them up
Old Sep 9, 2002 | 12:27 AM
Rpeck's Avatar
What R U thinking self?
Drilling could be scary anyways .. sparks N ****. I would heavily grease the drill bit if I were you ..
Old Sep 9, 2002 | 12:29 AM
Wankel Traitor
Lol, smart thinkin Scott .
Grab onto the screws with a huge pair of vice grips, and turn . I actually had to do this to get the pump off the bracket, the metal bracket that holds the pump onto the assembly has one screw in it that decided to give me a strip show (ponder that one).
Like scott said, you dont need to remove the pump to rewire it.
Jameson
Old Sep 9, 2002 | 08:37 AM
sunshine's Avatar
Craftsman has this new tool that is designed just for grabbing stripped screws. I dont know what its called, but go to a Sears and ask. It will make your life much easier.
Old Sep 9, 2002 | 10:18 AM
HAILERS's Avatar
HAILERS
Drill the heads off and grab the remaining shank with a pair of pliers after you lift the cover/pump out. They will come out willingly. Take the filter off the end of the pump and replace it or clean it with varnish remover. Clean tank while there.
No real need to do the above if doing a fuel pump rewire. Also no reason to think fuel pressure drop would cause the engine check light to come on imho. Could be wrong, don't think so.
Old Sep 9, 2002 | 12:24 PM
Aaron Cake's Avatar
Engine, Not Motor
Do a serach for "rant fuel pump screws" under my name. You'll find lots.
Old Sep 9, 2002 | 12:28 PM
Rpeck's Avatar
What do you suggest using to clean the tank?
Old Sep 9, 2002 | 12:49 PM
PraxRX7's Avatar
Fuel
hahaha good one!!
I think it is something to do with the fuel because since last night my A/F gauge (as unreliable they are for readings) is reading a lot closer to stoich then rich. (at WOT it used to always be pure rich, now it lights up quickly between far stoich and rich, almost like the "fuel save mode" where is bounces back and fourth only way faster.)
I definitly need to clean the in-tank filter and possibly the tank as much as possible. (its never been done, 180,000+ miles on the tank.)
I wish the engine light would stay on long enough for me to get error codes from it!! Yarg!!
Old Sep 9, 2002 | 01:55 PM
tesla042's Avatar
Here's my trick:
Get a wratchet, an extension, and a phillips "bit", and a hammer.
SMASH that bit into that ****
press down on the wratchet really hard as you un-screw it..
I stripped 4 of them with a normal screwdriver before figuring this trick out.. Got all 4 out on the first (er..second, technically, I guess) try.
Don't be afraid to really wail on it.. the screws are so malleable that the bit will sink into them with a bit of coaxing..
-Tesla
Old Sep 9, 2002 | 11:59 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Re: Fuel
if the light came on the code is stored. even if the light came on it wouldn't tell you the code... only if you check it will it tell you.
how to on my site
Old Sep 10, 2002 | 02:14 AM
silverrotor's Avatar
Be sure to replace the screws with 6mm s.s Hex head bolts.
Old Sep 10, 2002 | 07:53 AM
cbrock's Avatar
you could always get an impact screw driver. They're heavy, bout a foot long and you bash it with a hammer. It'll pop that thing loose damn quick.
Old Sep 10, 2002 | 09:25 AM
PraxRX7's Avatar
Re: Re: Fuel
how to on my site
Ah that is where I misunderstood, I didn't know the codes were stored, so unless the light was on when I shut off the car I wasn't even gong to try...
Thanks! I'll check them tonight.
Old Sep 11, 2002 | 02:01 AM
PraxRX7's Avatar
ouch
Code 11 - Air Intake thermostat
Code 12 - Throttle Sensor (full range)
Code 17 - Oxygen Sensor Voltage messed up (time for new one)
Code 18 - Throttle Sensor (narrow range)
Yarg...I have got my work cut out for me.
Old Sep 11, 2002 | 02:08 AM
Scott 89t2's Avatar
SOLD THE RX-7!
reset them (pull the battery) and drive and see if they all come back. they could have been old ones.
Old Sep 11, 2002 | 02:10 AM
PraxRX7's Avatar
thanks
Yea I reset the ECU before work today and drove it around all day/night here.
So lets see, adjust the TPS, change O2 sensor, replace intake air thermostat and check all electrical to these...
I'll be busy this weekend...oh well (I will see if my mechanic can fix these cheap, if it is less than $100 I'll just get him to do it).
Old Sep 11, 2002 | 02:42 AM
PraxRX7's Avatar
reset again...
I reset it again for longer this time, and drove around, so far the only one that has come back on was the code 17,
Thank.
Microtech
30
Apr 23, 2016 06:37 PM
rotor_veux
Sep 3, 2015 07:10 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
