FD Diff Size
Old Sep 7, 2002 | 04:05 PM
dorikin ichiban's Avatar
FD Diff Size
What is the size of the Diff in the FDs?
Cheers
John
Old Sep 7, 2002 | 04:35 PM
RE Diff....
Size of what???
Old Sep 7, 2002 | 07:05 PM
jspecracer7's Avatar
1JZ powered
Re: FD Diff Size
Cheers
John
Same size as the stock TII FC.
Old Sep 7, 2002 | 07:20 PM
dingleberry's Avatar
are you talking gear ratios?
Old Sep 7, 2002 | 09:38 PM
jimlab's Avatar
Super Snuggles
The FD's ring gear diameter is 8.0" (203mm) and it's fastened to the differential using 10 bolts. GM's 10-bolt ring gear is 7.5" in diameter and the 12-bolt is 8.875" in diameter, so the FD's ring gear is probably slightly stronger than a GM 10-bolt.
Shainiac
Jul 17, 2019 02:20 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
