Holley Carb Setup
Old Sep 6, 2002 | 03:23 PM
gonzz's Avatar
Holley Carb Setup
Got my Holley Carb setup. How should i run the metering pump to the carb? Also i need help making a throttle cable bracket. Anyuone got any pics of this setup?
Thanks, Gonzz
Old Sep 6, 2002 | 05:02 PM
REVHED's Avatar
Hunting Skylines
You'll probably have to tap some fittings into the manifold for the metering lines and find some way to hook the linkage up.
As for the throttle bracket... just use your imagination. For my Weber I used a couple parts off the Nikki and fabricated the rest from aluminium. Turned out really well.
Old Sep 7, 2002 | 03:38 AM
gonzz's Avatar
Got any pics?
Old Sep 7, 2002 | 08:31 AM
rxtasy3's Avatar
If ur carb is for a rotary, then the connection for the metering rod to the carb is already there, u just use the stock rod, as for the oil lines, use a vac "T" down at the pump to make the 2 lines into 1, then attach to the primary float bowl with nipple type fitting screwed in place where u check float level. This is the only pic I have so u can only see the vac hose I use for the oil line to the float bowl.
Old Oct 2, 2004 | 07:16 PM
813KR$'s Avatar
TEAM MAZDA
Pre mix !
And for a bracket use a alternator bracket and bend accordingly ! ! !
Old Oct 2, 2004 | 07:17 PM
813KR$'s Avatar
TEAM MAZDA
Screw the bracket on to the top of the engine.
Old Oct 2, 2004 | 07:36 PM
gonzz's Avatar
I am premixing now. Best thing I have ever done. No more OMP.
Old Oct 3, 2004 | 01:21 PM
MarkPerez's Avatar
Tennis, anyone
if your pre-mixxing, no reason to use the omp and lines. you know that, i know you do. the bracket should be pretty easy to fab up along with a return spring 'perch'. where you place the bracket will be important, make sure it's placed to where the pedals on the floor and the carb. is wide open.
FbFuninthesun
Oct 6, 2015 08:03 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
