A wire that shows when a manual FC is not in gear?
Old Sep 6, 2002 | 01:06 PM
SwooshMand's Avatar
I'm curious to know if anyone knows of a wire that shows when a manual FC is not in gear. Its for a security install that i'm planning. Any info would be appreciated. Thanks
Old Sep 6, 2002 | 01:13 PM
DaleClark's Avatar
RX-7 Bad Ass
I believe there is a neutral switch on the tranny that outputs whether or not the tranny is in neutral.
Dig through the shop manual.
Dale
Old Sep 6, 2002 | 04:39 PM
Icemark's Avatar
Nuetral safety switch wire is Green/black at the ECU or the switch.
Old Sep 6, 2002 | 10:08 PM
SwooshMand's Avatar
Icemark, you wouldn't happen to know weither its positive or negative? I'm assuming its negative. And i've read a few post's where you've stated that you've worked for DEI, you wouldnt happen to have the techsoft sheet for an 88, would ya? The information i have access to is only from i believe 90 and up. Thanks. BTW i'm a cc installer thats where i have access to Techsoft.
Old Sep 6, 2002 | 11:41 PM
Icemark's Avatar
Its a negitive trigger (ground when closed).
Actually the wire colors between a 90 and 88 are pretty much the same. The 86 was really the only year there were any differences.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
TerryD
Aug 23, 2015 07:40 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
PhillyFC
Aug 21, 2015 06:36 PM
Leeroy_25
Aug 17, 2015 12:53 PM
