Have 11.5 PSI on stock car
Old Sep 5, 2002 | 12:13 PM
TobiasRX's Avatar
My pattern is 11.5 8 10
My only mod is a custom 3" exhaust.
Old Sep 5, 2002 | 12:20 PM
TobiasRX's Avatar
oh and i've read that boost should drop to 8 psi when u're at 6000 rpm but for me it dropped at ca 5500 rpm. this could be because mine is european:
240 HP
redline at 7000 rpm.
Old Sep 5, 2002 | 12:32 PM
Dragueur's Avatar
u sure...
or is it just spikin to 11.5?? mines spike up there...usually durin transition though
Old Sep 5, 2002 | 12:48 PM
TobiasRX's Avatar
no it stays up there.
But if a spike is from 3000 rpm to transition in 4th gear then yes it is a spike. But i guess thats not a spike.
Old Sep 5, 2002 | 12:49 PM
OptusX4's Avatar
custom 3" exhaust straight through? I.e. no cat, no muffler, no pre-cat... don't get an intake. You're just experiencing boost spike from opening up the airflow. I'd get a home depot boost controller (do a search, you should find a plethora of info).
Old Sep 5, 2002 | 12:53 PM
TobiasRX's Avatar
no only the last part after the catback is 3"
Old Sep 5, 2002 | 01:45 PM
OptusX4's Avatar
So... you have a 3" exhaust tip? I don't understand why you're even getting 11.5psi then.
Old Sep 5, 2002 | 01:49 PM
Kahren's Avatar
i am not a girl
you coudl have torn hoses at the wastegate and prespool, i woudl check those out. make sure u check both sides, one where the air enters teh wastegate and the other where air exits and all teh way up to the solenoids. and might as well test teh solenoids too whil eu are at it
Old Sep 5, 2002 | 01:59 PM
TobiasRX's Avatar
ok thanks kahren
dkwasherexd
May 27, 2017 04:51 AM
Microtech
Aug 23, 2015 11:04 AM
Snook
Aug 15, 2015 08:18 AM
Turblown
Aug 14, 2015 04:48 PM
